[pgrouting-dev] K-Shortest Paths performance issues
Paulo Figueiras paf at uninova.pt
Thu Jan 23 14:34:28 PST 2014
Hi, Steve.
Thanks for your fast response.
The seems a little excessive to me, but I have not used it enough to have
> any idea what to expect.
So it seems :) I'm running pgrouting on a Ubuntu virtual machine with 2
cores and 4GB of RAM.
> Can you run ksp with k=1? or does it automatically adjust it upward to k=2?
> I can try to run with k=1, although I use Dijkstra or A* for single
routes. I would really like to use KSP for 2 to 5 route options.
> Does this happen for ALL cases? or only sometimes?
> I tried a few times and it is consistent.
> Can you make a small graph test case the shows this behavior? The can be
> used to debugging the problem.
> What I'll do is I'll migrate my code to a more powerful server this
weekend, and I'll test KSP with k=2 there to check for improvements. In the
meantime, I'll try k=1 in the virtual machine.
I'll report results next week. Again, thank you very much.
Best,
Paulo Figueiras <paf at uninova.pt <%3Crddc at uninova.pt>>
[image: cid:image002.jpg at 01C8AEC7.2F6E45A0] <http://www.uninova.pt/>
UNINOVA, Centre of Technology and Systems
Campus da Caparica, Quinta da Torre
2829-516 Monte Caparica, PORTUGAL
Phone: (+351) 212948312 | Fax: (+351) 212957786 | Website:
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20140123/7cc5ff02/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20140123/7cc5ff02/attachment.jpg>
More information about the pgrouting-dev mailing list
