[pgrouting-dev] [OSGeo-Discuss] New to OSGeo
Stephen Woodbridge woodbri at swoodbridge.com
Thu Jan 30 07:38:52 PST 2014
Hi Pulkit,
First it would be a good idea to get on the pgrouting-dev list:
pgrouting-dev mailing list
pgrouting-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Then you can look at:
https://github.com/pgRouting/pgrouting/wiki/Developer---Getting-Started
and the other links here:
http://pgrouting.org/ -- look at the user docs and the new workshop
There are a bunch of people on the list that can help
Thanks,
   -Steve
On 1/30/2014 3:54 AM, Pulkit Agarwal wrote:
> Hi Steve,
> I went through the all the three Readme and things are no quite clear to
> me. What I think we have to install
>   * postgresql-server-dev-9.2
>   * libpq-dev
>   * libpqxx3-dev
>   * libcurl4-gnutls-dev
>   * libjson0-dev.
> I followed the link to install.
> https://gist.github.com/chen206/4030441
> I mean just by installing the above mentioned packages will we be able
> to set up the project.
> As I am new to postgresql and pgrouter please guide me with all the
> basics of installing the project on my laptop.
> Thanks,
> Pulkit
> On Wed, Jan 29, 2014 at 10:45 AM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>     Hi Pulkit,
>     You might also be interested in looking at
>     https://github.com/woodbri/__osrm-tools
>     <https://github.com/woodbri/osrm-tools>
>     This is a tool the extracts pgRouting data into a format that can be
>     loaded into Project-OSRM (the high performance routing engine for OSM)
>     And a postgresql extension that allows you to access OSRM from
>     inside the database.
>     I have combine these to to allow you to select a number of points on
>     a map and then compute a distance matrix using the osrm-tools and
>     optimizing the order of the points use pgRouting TSP function. then
>     passing the results back to the web application to display them.
>     The osrm-tools can also be used to compute distance matrices needed
>     for the VRP solution.
>     I think picking another VRP problem or enhancing the current one to
>     add more functionality might be a good project.
>     Another interesting project might be to build an asymmetric TSP
>     solver. Our current solver uses simulated annealing but it assumes a
>     symmetric matrix.
>     Daniel might have some additional ideas about additional VRP
>     solutions that we might need.
>     If you have time, jump in and start working on a small project that
>     might interest you or we can point out a bug that might need fixing.
>     In the past students that jumped in early and started working
>     learned a lot of the basics so when they got selected for GSoC, they
>     had more time to focus on doing something fun stuff rather than
>     learning the basics of how to deal with coding in the postgresql
>     server environment.
>     Thanks,
>        -Steve
>     On 1/28/2014 3:13 PM, Pulkit Agarwal wrote:
>         Hi Steve,
>         I went through the project ideas and what i have come up with is the
>         projects aim at developing routing software with large data
>         which forces
>         it to go toward AI algorithms in collaboration with osm. Let me
>         inform
>         what exactly i did i the project i mentioned in my first mail.
>         It was a
>         cross platform offline routing software specific to our college
>         campus(
>         hence named campus mapping software) which used osm and the
>         functionalities were implemented over it.So I understand most of the
>         basics of doing these functionalities. Also Tabu search and other
>         heuristic based based algorithms  are covered in our Artificial
>         Intelligence course, so i am familiarized with these also.
>         Overall I think if the projects will be on similar areas i will
>         do well
>         and live upto the project expectation .Looking forward to work
>         with this
>         organization.
>         Thanks,
>             -Pulkit.
>         On Wed, Jan 29, 2014 at 12:59 AM, Stephen Woodbridge
>         <mailto:woodbri at swoodbridge.__com
>         <mailto:woodbri at swoodbridge.com>>> wrote:
>              On 1/28/2014 2:09 PM, Alex Mandel wrote:
>                  On 01/28/2014 11:04 AM, Pulkit Agarwal wrote:
>                      Hello,
>                      I'm new to OSGeo and would like to contribute.
>                      I read the various prerequisites in terms of
>         knowledge of
>                      different
>                      platforms of the organization. And i have basic idea of
>                      almost all the
>                      platforms mentioned. In-fact i worked on an
>         academic project
>                      involving Open
>                      street maps.At the moment, I don't have a
>         particular area in
>                      mind but I'm
>                      excited to work in various interesting topics. So
>         how should
>                      I start?
>                      I'm also looking up to GSOC 2014 and perhaps do a
>         project
>                      for OSGeo. Where
>                      should I get the latest news regarding it like the
>         list of
>                      projects,
>                      mentors etc.?
>                      Regards,
>                      Pulkit Agarwal
>                  Welcome,
>                  We haven't started a 2014 GSOC page yet on the
>         wiki.osgeo.org <http://wiki.osgeo.org>
>                  <http://wiki.osgeo.org> but there
>                  is a mailing list:
>         http://lists.osgeo.org/____mailman/listinfo/soc
>         <http://lists.osgeo.org/__mailman/listinfo/soc>
>         <http://lists.osgeo.org/mailman/listinfo/soc>>
>              Hi Pulkit,
>              You can also check in with any of the projects that
>         interest you and
>              I think you will find that most can give you some idea of
>         potential
>              GSoC Ideas for their projects.
>              For example pgRouting has:
>         https://github.com/pgRouting/____pgrouting/wiki/GSoC-Ideas
>         <https://github.com/pgRouting/__pgrouting/wiki/GSoC-Ideas>
>         <https://github.com/pgRouting/pgrouting/wiki/GSoC-Ideas>>
>              Our experience through the years that students the pick
>         projects
>              that they are interested in or passionate about tend to
>         learn more
>              and have more fun working on them and are the most successful.
>              You are not constrained to pick an existing idea. If you
>         have some
>              ideas bounce them off the project lists and work with them
>         to fine
>              tune your ideas or come up with other ideas.
>              There is nothing better than working on a project that
>         excites you.
>              Best Regards,
>                 -Steve
>              ___________________________________________________
>              Discuss mailing list
>         Discuss at lists.osgeo.org <mailto:Discuss at lists.osgeo.org>
>         <mailto:Discuss at lists.osgeo.__org <mailto:Discuss at lists.osgeo.org>>
>         http://lists.osgeo.org/____mailman/listinfo/discuss
>         <http://lists.osgeo.org/__mailman/listinfo/discuss>
>         <http://lists.osgeo.org/mailman/listinfo/discuss>>
More information about the pgrouting-dev mailing list
