[pgrouting-dev] Optimal Meeting Point (OMP)
Luís de Sousa luis.a.de.sousa at gmail.com
Thu Jul 17 00:59:32 PDT 2014
Hello everyone,
I am following the Wiki to set up a development environment, but compiling
pgRouting is becoming a bit of a saga. Right now I am stuck with cmake
unable to find Boost:
CMake Error at /usr/share/cmake-2.8/Modules/FindBoost.cmake:1131 (message):
  Unable to find the requested Boost libraries.
  Boost version: 1.54.0
  Boost include path: /usr/include
  Could not find the following Boost libraries:
          boost_thread
          boost_system
  No Boost libraries were found.  You may need to set BOOST_LIBRARYDIR to
the
  directory containing Boost libraries or BOOST_ROOT to the location of
  Boost.
Call Stack (most recent call first):
  cmake/FindCGAL.cmake:42 (find_package)
  CMakeLists.txt:303 (find_package)
I am on Ubuntu 14.04. A few outputs from my system:
$ dpkg -l | grep boost
ii  libboost-date-time1.54.0:amd64
1.54.0-4ubuntu3.1                                   amd64        set of
date-time libraries based on generic programming concepts
ii  libboost-dev
1.54.0.1ubuntu1                                     amd64        Boost C++
Libraries development files (default version)
ii  libboost-graph-dev:amd64
1.54.0.1ubuntu1                                     amd64        generic
graph components and algorithms in C++ (default version)
ii  libboost-graph1.54-dev:amd64
1.54.0-4ubuntu3.1                                   amd64        generic
ii  libboost-graph1.54.0:amd64
ii  libboost-iostreams-dev:amd64
Boost.Iostreams Library development files (default version)
ii  libboost-iostreams1.54-dev:amd64
ii  libboost-iostreams1.54.0:amd64
ii  libboost-regex1.54-dev:amd64
1.54.0-4ubuntu3.1                                   amd64        regular
expression library for C++
ii  libboost-regex1.54.0:amd64
ii  libboost-serialization1.54-dev:amd64
serialization library for C++
ii  libboost-serialization1.54.0:amd64
ii  libboost-system1.54.0:amd64
1.54.0-4ubuntu3.1                                   amd64        Operating
system (e.g. diagnostics support) library
ii  libboost-test1.54-dev:amd64
1.54.0-4ubuntu3.1                                   amd64        components
for writing and executing test suites
ii  libboost-test1.54.0:amd64
ii  libboost-thread1.46.1
1.46.1-7ubuntu3                                     amd64        portable
C++ multi-threading
ii  libboost1.54-dev
1.54.0-4ubuntu3.1                                   amd64        Boost C++
$ locate boost_thread
/usr/lib/libboost_thread.so.1.46.1
$ locate boost_system
/usr/lib/x86_64-linux-gnu/libboost_system.so.1.54.0
$ whereis boost
boost: /usr/include/boost
$ cat /etc/environment | grep BOOST
BOOST_LIBRARYDIR="/usr/lib/x86_64-linux-gnu/:/usr/lib/"
BOOST_ROOT="/usr/include/boost"
Any ideas on why isn't cmake finding Boost? Thank you,
Luís
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20140717/8a8197c2/attachment.html>
More information about the pgrouting-dev mailing list
