[pgrouting-dev] Boost graph algorithm
Adrien ANDRÉ adrien.andre at onf.fr
Mon Mar 10 03:52:44 PDT 2014
Stephen, thank you for your answer.
Despite not being at ease with tools as Git and CMake or C/C++
development and compilation, i began following steps you described.
Here is the new branch:
https://github.com/adrienandrem/pgrouting/tree/components
I've noticed the
https://github.com/pgRouting/pgrouting/wiki/Developer---Getting-Started
page, and will keep you informed of my progress.
Regards,
Adrien
On 26/02/2014 11:52, Stephen Woodbridge wrote:
> On 2/26/2014 9:22 AM, Adrien ANDRÉ wrote:
>> Hi all,
>> prior to routing, i'd like to extract connected components from my
>> network.
>> Reading the mailing list i've learned this algorithm is implemented in
>> the boost graph library.
>> Could you tell me what are the main steps to make this algorithm
>> available from my database?
>> Or, could you advise me an existing tutorial about this?
> Hi Adrien,
> On the wiki are some pages on development and getting started.
> Basically the process we use is to have people look at pgr_dijkstra()
> function as this is pretty simple and it uses boost.
> src/dijkstra and clone this into your own directory
> Update the CMakeLists.txt file here and below and change the name of the
> files to your algorithm
> src/dijkstra/doc -- is for your doc files
> src/dijkstra/sql -- is the code the links the sql function to the C/C++
> code
> src/dijkstra/src -- is you C/C++ code
> src/dijkstra/test -- are your test files for the automated test system
> src/dijkstra/tester -- can be used to write a command lin test tool that
> test your code outside of the database
> Jump right in and ask questions when you are confused or need help.
> Oh, I recommend that you go to github and fork the pgrouting project
> into your account, then clone you fork, and create a branch off of
> master or develop and do you development in that branch. Then when you
> have code to submit back you can generate a pull request that is easy
> for us or other to merge back into the main development branch.
> Thanks,
>   -Steve
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20140310/8f11be89/attachment.vcf>
More information about the pgrouting-dev mailing list
