[pgrouting-dev] Finally getting back to integrating your TRSP improvements
Stephen Woodbridge woodbri at swoodbridge.com
Mon May 5 20:22:40 PDT 2014
Hi Helder,
I discussed this with Roni and my approach is probably reasonable but
there are a lot of details and corner cases that need to be dealt with.
So I will probably leave these changes to Roni as he has a beter handle
on it than I do. He is hoping to have some time this summer to work on this.
So I checked in his code fixes and enhancements into the develop branch.
The enhancements only have the C++ code in GraphDefinition.{cpp,h} but
this has not be exposed to the SQl yet because I think we should do this
as part of making a clean consistent interface. You can see I started to
work this out in the discussion below. But didn't get much further than
that.
-Steve
On 5/5/2014 3:33 AM, Helder Alves wrote:
> Hi Steve and all!
> Do you have any advance on this matter? :-)
> Thanks!
> Helder Alves
> On Apr 14, 2014 4:05 PM, "Stephen Woodbridge" <woodbri at swoodbridge.com
> <mailto:woodbri at swoodbridge.com>> wrote:
>     On 4/13/2014 3:08 PM, Ashraf Hossain wrote:
>         Dear Steve,
>         I am out of town in village, I will come back to you soon with
>         my thoughts.
>     Hi Roni,
>     No problem, enjoy your time being mostly disconnected from the net :)
>     Looking at GraphDefinition.cpp, I'm thinking that a small
>     refactoring might make it easier to deal with multi_dijkstra using
>     edges versus nodes. Something along the lines of:
>     vector<int> GraphDefinition::__makeVirtualNodes(vector<int>
>     edge_ids, vector<double> edge_parts);
>     This could take a list of edges and position on the edges and create
>     a vector of virtual nodes and add then to the graph and return
>     vector of the new virtual node ids. Then in multi_dijkstra you can
>     loop through these as the start and end nodes. If we only have one
>     start and end then the existing code could be change to work with
>     this vector.
>     And it would be easy to change or clone multi_dijkstra to add
>     options for one_to_many and many_to_many loops.
>     We could also eliminate the existing edge to edge version of
>     my_dijkstra or trivialize it to call multi_dijkstra where we pass it
>     just a vector of the start and end points. This would remove
>     redundant code and simplify testing and verification of the existing
>     code.
>     Any thoughts on this when you have a chance to look over the code.
>     I'm not sure what the best way to do this in GraphDefinition. It
>     looks like we have a few places where we check
>     if(is<Start|End>Virtual) when evaluating restrictions because this
>     gets a little trickier. If the node is a via point in the middle of
>     a restriction, then we will continue on that edge as if there is no
>     virtual node there, but if it is the first or last point in overall
>     route we will treat it like the start or end case as we do now. In
>     the case of one_to_many and many_to_many, the start and end points
>     would get treated as they are now also.
>     I'm thinking that with these changes, we could potentially also
>     replace pgr_dijkstra and pgr_kdijkstra with the trsp code so we have
>     one common code base for
>     pgr_dijkstra()            - pgr_trsp() point_to_point
>     pgr_kdijkstra()           - pgr_trsp() one_to_many
>     pgr_makeDistanceMatrix()  - pgr_trsp() many_to_many
>     We would be able to support turn restrictions or not with all these
>     functions.
>     One question I have about trsp is when I do a dijkstra solution in
>     Boost, I solve the whole graph so in the kdijkstra case
>     (one_to_many) I make one solution of the graph and I can extract
>     paths to the "many" end nodes in the graph rather than doing
>     multiple solves like A-B, A-C, A-D, ...? Can we do the same (extract
>     multiple end points) in trsp? If so then many_to_many becomes (N *
>     one_to_many).
>     Hope this all makes some sense.
>     Thanks,
>        -Steve
>         Regards
>         Roni
>         On Sun, Apr 13, 2014 at 6:28 AM, Stephen Woodbridge
>         <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>
>         <mailto:woodbri at swoodbridge.__com
>         <mailto:woodbri at swoodbridge.com>>> wrote:
>              Hi Roni,
>              I hope you and your family are doing well.
>              I am well but have been very busy. I'm between some
>         contracts at the
>              moment and I am looking at the TRSP improvements you did
>         quite a
>              ways back to add the reverse cost and routing from nodes
>         A-B-C-...
>              Looking at multi_dijkstra it seems that I should be able to
>         mimic
>              that code based on how you clean up after each route A-B to
>         restart
>              for B-C and create a similar function that computes one to many
>              destinations, A-B, A-C, A-D, etc.
>              What do you think?
>              So for integrating this code, I probably need to implement
>         a family
>              of additional functions like:
>              Existing functions:
>              pgr_trsp(text, integer, integer, boolean, boolean)
>              -- node to node
>              pgr_trsp(text, integer, integer, boolean, boolean, text)
>              -- node to node with restrictions
>              pgr_trsp(text, integer, double precision, integer, double
>         precision,
>              boolean, boolean)
>              -- edge to edge
>         precision,
>              -- edge to edge with restrictions
>              pgr_trsp(text, integer[], boolean, boolean, text)
>              -- array of nodes **this gets changed to use new code (1)**
>              pgr_trsp(text, integer[], float8[], boolean, boolean, text)
>              -- array of edges **this gets changed to use new code (2)**
>              (1) should plug directly into your code. I currently do
>         this in C by
>              calling your old code multiple times, but it will be more
>         efficient
>              to change this to call multi_dijkstra because we only build the
>              graph once.
>              (2) I currently do this in C by making multiple calls to
>         your old
>              code. The multi_dijkstra only accepts nodes, not edges, so
>         I'll look
>              at making a version that can be called by edges. Unless you
>         want to
>              do that :)
>              Then I think I would like to add a new argument to (1) and
>         (2) above
>              "boolean onetomany" and if it is true then we compute A-B,
>         A-C, A-D,
>              ... and if it is false it will compute A-B-C-...
>              I'll have to think about how to return the results, but
>         that should
>              not be too hard.
>              TODO:
>              1. create function to support multi_dijkstra with edges
>              2. create new function onetomany_dijkstra for nodes
>              3. create new function onetomany_dijkstra for edges
>              4. update C code wrappers to support the above
>              5. develop test cases
>              6. write the documentation
>              7. check it in
>              Ok that is a bunch of work! Maybe I'll start with just
>         getting (1)
>              done so it calls your new code, and write a test case for
>         that. Then
>              tackle the rest.
>              Thoughts?
>              -Steve
>     _________________________________________________
>     pgrouting-dev mailing list
>     pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
>     http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev
>     <http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
More information about the pgrouting-dev mailing list
