[pgrouting-dev] difference between st_convexhull and pgr_pointsAsPolygon
Vicky Vergara vicky_vergara at hotmail.com
Mon Apr 13 18:23:24 PDT 2015
> Date: Mon, 13 Apr 2015 20:50:47 +0100
> From: dave.potts at pinan.co.uk
> To: pgrouting-dev at lists.osgeo.org
> Subject: [pgrouting-dev] difference between st_convexhull and	pgr_pointsAsPolygon
> Hi list
> I am doing some with the end results of a driving distance calculation,
> I can use either st_convexhull or pgr_pointsAsPolygon to turn the end
> results in to a polygon
> Q. What is the advantage of using pgr_pointsAsPolygon instead of using
> st_convexhull?
> regards
> Dave.
> pgrouting-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
By inspecting pgRouting code, there is some checking taking place...
https://github.com/pgRouting/pgrouting/blob/develop/src/driving_distance/sql/routing_dd.sql#L77
But now that you are one it, does it give you different results?
Vicky.
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20150413/930de7fb/attachment.html>
More information about the pgrouting-dev mailing list
