[pgrouting-dev] How do I work on pgRouting documentation?
Vicky Vergara vicky at georepublic.de
Sun Jul 10 09:07:13 PDT 2016
cd build/
cmake  -DWITH_DOC=ON ..
make doc
cd ..
the documentation will be on:
cd build/doc/html/en/doc/
On Sun, Jul 10, 2016 at 9:42 AM, Daniel Kastl <daniel at georepublic.de> wrote:
> This is my own memo how to build pgRouting with documentation, and how to
> publish it to GH-Pages and Transifex:
> https://gist.github.com/dkastl/5617030
> Vicky did the documentation updates in the past months, so I'm not sure
> all dependencies and commands are still 100% the same with newer versions
> of Ubuntu for example.
> But I just run this part and it worked for me:
> https://gist.github.com/dkastl/5617030#file-build_pgrouting-sh-L9-L13heers
> At least "html" worked for me. It seems PDF generation has errors.
> Cheers,
> Daniel
> On Sun, Jul 10, 2016 at 11:16 PM, Worth Lutz <wal3 at mindspring.com> wrote:
>> I tried all that and do not see where the updated documentation ends up.
>> After doing the build, pointing to:
>>     ~/pgrouting/build/doc/html/index.html
>> does not seem to work for me. I'm obviously missing something.
>> Thanks,
>> *Worth Lutz*
>> On 7/9/2016 10:06 AM, Daniel Kastl wrote:
>> Sorry, should be "cmake" of course.
>> ... auto correction...
>> On Jul 9, 2016 11:05 PM, "Daniel Kastl" <daniel at georepublic.de> wrote:
>>> The documentation is compiled with cake using a special compile flag,
>>> see https://github.com/pgrouting/pgrouting/tree/develop#compilation
>>> We probably need to make this easier to find in the documentation ;-)
>>> Cheers,
>>> Daniel
>>> On Jul 9, 2016 9:15 PM, "Worth Lutz" <wal3 at mindspring.com> wrote:
>>>> I have been side tracked a bit but have been reading the documentation
>>>> extensively over the past week. I have had some success working with my
>>>> data and will be rereading the docs to make sure my understanding is
>>>> correct. I'll then commit the corrections and additions I'm working on.
>>>> How do I run the docs locally.  I am familiar with Sphinx but have not
>>>> found the place to
>>>> *make html*
>>>> I see a *make.bat* file but that is for Windows.  I normally work on
>>>> Ubuntu and have a *Makefile* in the directory as well as *make.bat*.
>>>> Is development normally done on Windows? And thus the *Makefile *removed
>>>> when make.bat was edited?
>>>> Thanks for your help.
>>>> *Worth Lutz*
>>>> On 7/8/2016 11:18 PM, Vicky Vergara wrote:
>>>> I merged code and more documentation to develop.
>>>> Here is a helpful link for keeping up to date the branches:
>>>> http://docs.pgrouting.org/doxy/2.3-dev-develop/index.html#up_to_date
>>>> On Wed, Jun 22, 2016 at 7:57 PM, Vicky Vergara < <vicky at georepublic.de>
>>>> vicky at georepublic.de> wrote:
>>>>> Thanks
>>>>> On Wed, Jun 22, 2016 at 2:10 PM, Worth Lutz < <wal3 at mindspring.com>
>>>>>> Vicky,
>>>>>> My github is at:
>>>>>>     https://github.com/worthlutz/pgrouting/
>>>>>> The branch I'll be using is *doc-improvements* branched off *develop*
>>>>>> I'll let you know when I push some changes.
>>>>>> *Worth Lutz*
>>>>>> On 06/22/2016 02:06 PM, Vicky Vergara wrote:
>>>>>> Tell when you make the branch
>>>>>> so I can pinpoint where to find the docuemtnation
>>>>>> On Wed, Jun 22, 2016 at 12:58 PM, Worth Lutz < <wal3 at mindspring.com>
>>>>>>> Thanks Vicky.  I'll let you know what I find.
>>>>>>> *Worth Lutz*
>>>>>>> On 6/22/2016 1:53 PM, Vicky Vergara wrote:
>>>>>>> Hello Worth Lutz.
>>>>>>> The documentation changes you made them to master or to develop?
>>>>>>> Right now develop documentation has changed, not in everything put
>>>>>>> it has lots of changes.
>>>>>>> <http://docs.pgrouting.org/dev/en/doc/index.html>
>>>>>>> It is better for us to work on the develop branch which has the 2.3
>>>>>>> documentation.
>>>>>>> Its changing a lot. so to have the current contents of develop in
>>>>>>> your for:
>>>>>>> git checkout develop
>>>>>>> git fetch upstream
>>>>>>> git merge upstream/develop
>>>>>>> git push
>>>>>>> then in the github site you will be able to see that it contains the
>>>>>>> current contents of develop.
>>>>>>> Then you can branch to a working directory
>>>>>>> git checkout -b 'improve/documentation'
>>>>>>> then do a
>>>>>>> git push
>>>>>>> and give me the link to the branch in your repository so that if I
>>>>>>> make changes to develop's documentation, I can make a pull request to your
>>>>>>> branch with the changes I made.
>>>>>>> Work on the documentation, and make pull requests to develop.
>>>>>>> thanks.
>>>>>>> Vicky from the pgRouting team
>>>>>>> On Wed, Jun 22, 2016 at 12:10 PM, Worth Lutz < <wal3 at mindspring.com>
>>>>>>>> If I want to work on some errors/typos in the documentation, how do
>>>>>>>> I do that?
>>>>>>>> I've got a fork and want to create a pull request.
>>>>>>>> Which branch should I be working on?
>>>>>>>> As I'm starting a new routing project, I'm reading (and rereading)
>>>>>>>> the documentation a lot and think I should fix what I find.
>>>>>>>> *Worth Lutz*
>>>>>>>> _______________________________________________
>>>>>>>> pgrouting-dev mailing list
>>>>>>>> <pgrouting-dev at lists.osgeo.org>pgrouting-dev at lists.osgeo.org
>>>>>>>> <http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
>>>>>>> Georepublic UG (haftungsbeschränkt)
>>>>>>> Salzmannstraße 44,
>>>>>>> 81739 München, Germany
>>>>>>> Vicky Vergara
>>>>>>> Operations Research
>>>>>>> eMail: vicky at georepublic.de
>>>>>>> Web: https://georepublic.info
>>>>>>> Tel: +49 (089) 4161 7698-1
>>>>>>> Fax: +49 (089) 4161 7698-9
>>>>>>> Commercial register: Amtsgericht München, HRB 181428
>>>>>>> CEO: Daniel Kastl
>>>>>>> pgrouting-dev mailing listpgrouting-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>>>>>> Salzmannstraße 44,
>>>>>> Vicky Vergara
>>>>>> Operations Research
>>>>>> CEO: Daniel Kastl
>>>>> Salzmannstraße 44,
>>>>> Vicky Vergara
>>>>> Operations Research
>>>>> CEO: Daniel Kastl
>>>> Salzmannstraße 44,
>>>> Vicky Vergara
>>>> Operations Research
>>>> CEO: Daniel Kastl
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.info
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20160710/9124d0c3/attachment-0001.html>
More information about the pgrouting-dev mailing list
