[pgrouting-dev] [GSoC] Report - Flow algorithms for pgRouting - Week 2
Andrea Nardelli nrd.nardelli at gmail.com
Sun Jun 5 03:39:38 PDT 2016
Hi all,
I am working on the implementation of maximum flow algorithms and their
applications for pgRouting during the GSoC 2016. This is my second report.
1) What did you get done this week?
I implemented an additional wrapper using Boost and wrote some tests. I
cleaned up/refactored some of the code, in particular the common library
between all the implementations(the one that handles creating the graph and
returning the results).
2) What do you plan on doing next week?
As written in my application, next week I won't be able to work as much due
to finals at my university. However, I think I can manage to add the last
implementation from Boost.
3) Are you blocked on anything?
No, but I need to learn how to write the documentation more efficiently.
You can check the branch I'm working on here:
https://github.com/Illedran/pgrouting/tree/gsoc-flow
Best regards,
Andrea Nardelli
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20160605/d961aef1/attachment.html>
More information about the pgrouting-dev mailing list
