[pgrouting-dev] Upgrading to 2.2
dave.potts at pinan.co.uk dave.potts at pinan.co.uk
Fri Mar 4 11:37:28 PST 2016
Thanks Vcky
Just how do you invoke the test sequence?
There does not seem to be a test target in the makefile
Dave,
4 March 2016 13:54, "Vicky Vergara"  wrote:
Hi Dave:
This is what gets installed (beta1):
-- Installing: /usr/lib/postgresql/9.3/lib/libpgrouting-2.2.so
-- Installing: /usr/share/postgresql/9.3/extension/pgrouting--2.2.0.sql
-- Installing: /usr/share/postgresql/9.3/extension/pgrouting.control
-- Installing: /usr/share/postgresql/9.3/extension/pgrouting--2.0.0--2.2.0.sql
-- Installing: /usr/share/postgresql/9.3/extension/pgrouting--2.0.1--2.2.0.sql
-- Installing: /usr/share/postgresql/9.3/extension/pgrouting--2.1.0--2.2.0.sql
V.
> Date: Fri, 4 Mar 2016 09:56:27 +0000
> From: dave.potts at pinan.co.uk (mailto:dave.potts at pinan.co.uk)
> To: pgrouting-dev at lists.osgeo.org (mailto:pgrouting-dev at lists.osgeo.org)
> Subject: [pgrouting-dev] Upgrading to 2.2
> Hi List,
> When upgrading to a different version off Postgis, they supply an upgrade script to update the current database to the new release.
> Will pgroute 2.2 have a script as well?
> D
> pgrouting-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev (http://lists.osgeo.org/mailman/listinfo/pgrouting-dev)
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20160304/e8ddd319/attachment.html>
More information about the pgrouting-dev mailing list
