[pgrouting-dev] Upgrading to 2.2
Vicky Vergara vicky_vergara at hotmail.com
Fri Mar 4 12:22:29 PST 2016
Hi Dave,
There is never being a test target, (CMakelists needs to be improved)
http://docs.pgrouting.org/v2.2.0-beta1/doc/src/installation/install-dependencies.html#pgtap-pg-prove-perl-for-tests
how to test:
1) this is the v2.0.0 style testing
tools/testers/algorithm-tester.pl
2) I am gradually moving tests to use pgTap & pg_prove
Note: the CMakelists.txt does not check yet for that to exist
createdb  ___pgr___test___
sh ./tools/testers/pg_prove_tests.sh <usrname>
dropdb  ___pgr___test___
hope it helps.
V.
Date: Fri, 4 Mar 2016 19:37:28 +0000
To: pgrouting-dev at lists.osgeo.org
Subject: Re: [pgrouting-dev] Upgrading to 2.2
Thanks Vcky
Just how do you invoke the test sequence?
There does not seem to be a test target in the makefile
Dave,
4 March 2016 13:54, "Vicky Vergara" <vicky_vergara at hotmail.com> wrote:Hi Dave:
This is what gets installed (beta1):
-- Installing: /usr/lib/postgresql/9.3/lib/libpgrouting-2.2.so
-- Installing: /usr/share/postgresql/9.3/extension/pgrouting--2.2.0.sql
-- Installing: /usr/share/postgresql/9.3/extension/pgrouting.control
-- Installing: /usr/share/postgresql/9.3/extension/pgrouting--2.0.0--2.2.0.sql
-- Installing: /usr/share/postgresql/9.3/extension/pgrouting--2.0.1--2.2.0.sql
-- Installing: /usr/share/postgresql/9.3/extension/pgrouting--2.1.0--2.2.0.sql
V.
 > Date: Fri, 4 Mar 2016 09:56:27 +0000
> From: dave.potts at pinan.co.uk
> Subject: [pgrouting-dev] Upgrading to 2.2
> Hi List,
> When upgrading to a different version off Postgis, they supply an upgrade script to update the current database to the new release.
> Will pgroute 2.2 have a script as well?
> D
> pgrouting-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20160304/7a5989dc/attachment.html>
More information about the pgrouting-dev mailing list
