[pgrouting-dev] boost version?
Vicky Vergara vicky at georepublic.de
Thu Sep 29 10:13:47 PDT 2016
Hello Devrim:
This is the smallest boost version I tried (based on trusty default boost
version it has)
 Boost version: 1.46.1
And is the "official" minimum version.
https://github.com/pgRouting/pgrouting#requirements
As you can see here:
https://github.com/pgRouting/pgrouting/blob/master/CMakeLists.txt#L265
I am really enforcing a minimal version on boost
I did try on an attempt to use boost::geometry instead of CGAL (and
remove a dependency) but boost geometry appears to be in other boost
version
http://stackoverflow.com/questions/37003787/travis-ci-cant-find-boost-geometry-hpp
So, I rolled back.
Now, by looking at boost documentation.
the new flow algorithms (on the experimental & proposed functions
section) did exist on boost graph 1.41
http://www.boost.org/doc/libs/1_41_0/libs/graph/doc/table_of_contents.html
So "theoretically" I think it will work.
Give it a try and keep me informed so I can change the "official" but
not enforced (yet) minimum version.
Vicky
On Thu, Sep 29, 2016 at 11:09 AM, Devrim Gündüz <devrim at gunduz.org> wrote:
> Hi,
> I'm sure I checked this with Regina before, but forgot the answer: What is
> the
> minimum boost version for pgrouting 2.3.0? RHEL has 1.41, and wanted to
> make
> sure that it will work.
> Can you please confirm?
> Thanks!
> Regards,
> Devrim GÜNDÜZ
> EnterpriseDB: http://www.enterprisedb.com
> PostgreSQL Danışmanı/Consultant, Red Hat Certified Engineer
> Twitter: @DevrimGunduz , @DevrimGunduzTR
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky at georepublic.de
Web: https://georepublic.info
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20160929/10a7c752/attachment.html>
More information about the pgrouting-dev mailing list
