[pgrouting-dev] TRSP
Stephen Woodbridge woodbri at swoodbridge.com
Mon Oct 2 08:13:16 PDT 2017
Vicky,
This is awesome news! and a much needed step toward cleaning up the code
and making it more supportable. I quick perusal of the new code does
indeed show it to be more readable and much easier to understand.
Thank you for all your efforts to make pgrouting better! It really show
in the quality of the project.
Thanks,
   -Steve
On 10/2/2017 10:56 AM, Vicky Vergara wrote:
> Hello all
> I made a rewrite of the original TRSP (no changes for vias, no changes
> for points)
> Its not complete (converting the graph to boost graph its still missing)
> Branch is here:
> https://github.com/cvvergara/pgrouting/tree/rewritte-trsp2
> you can compare the original C code
> https://github.com/cvvergara/pgrouting/blob/rewritte-trsp2/src/trsp/trsp.c
> with the new code C code
> https://github.com/cvvergara/pgrouting/blob/rewritte-trsp2/src/trsp/new_trsp.c
> The old driver file:
> https://github.com/cvvergara/pgrouting/blob/rewritte-trsp2/src/trsp/trsp_core.cpp
> The new driver file:
> https://github.com/cvvergara/pgrouting/blob/rewritte-trsp2/src/trsp/trsp_driver.cpp
> And the old C++ code
> https://github.com/cvvergara/pgrouting/blob/rewritte-trsp2/src/trsp/GraphDefinition.cpp
> with the new C++ code
> https://github.com/cvvergara/pgrouting/blob/rewritte-trsp2/src/trsp/edgeInfo.cpp
> https://github.com/cvvergara/pgrouting/blob/rewritte-trsp2/src/trsp/rule.cpp
> https://github.com/cvvergara/pgrouting/blob/rewritte-trsp2/src/trsp/pgr_trspHandler.cpp
> With these changes:
> - pointers are no longer used (no leaks)
> - the code is more readable (so I think),
> - ​I has the one to one, one to many, many to one and many to many versions:
> https://github.com/cvvergara/pgrouting/blob/rewritte-trsp2/sql/trsp/trsp.sql
>> they all call this function:
> https://github.com/cvvergara/pgrouting/blob/rewritte-trsp2/sql/trsp/_trsp.sql
> - The sql files for the postgres (not underscored functions):
> https://github.com/cvvergara/pgrouting/blob/rewritte-trsp2/sql/trsp/trsp_V2.2.sql
> https://github.com/cvvergara/pgrouting/blob/rewritte-trsp2/sql/trsp/viaVertices_v2.2.sql
> Use the new _pgr_trsp where is appropriate
> - sorry no documentation yet, just the queries results on these notes
> are updated
> https://github.com/cvvergara/pgrouting/tree/rewritte-trsp2/doc/trsp
>    (I haven't gone through the text of the notes to update the text
> based on the results)
> - The sql functions are still underscored because the missing part of
> the rewrite
>   - Its not complete (converting the graph to boost graph its still missing)
> For those who are using one way or another the pgr_trsp(one to one)
> version If you can give these a try, and see if you find any issue about it.
> I will be merging to develop next monday up to this changes
> So any comments would be greatly appreciated.
> I am normally on gitter
> https://gitter.im/pgRouting/pgrouting
> Vicky
> Georepublic UG (haftungsbeschränkt)
> Salzmannstraße 44,
> 81739 München, Germany
> Vicky Vergara
> Operations Research
> eMail: vicky at georepublic.de <http://georepublic.de>
> Web:https://georepublic.info
> Tel: +49 (089) 4161 7698-1
> Fax: +49 (089) 4161 7698-9
> Commercial register: Amtsgericht München, HRB 181428
> CEO: Daniel Kastl
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/pgrouting-dev
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
More information about the pgrouting-dev mailing list
