[pgrouting-dev] withPoints(): possible memory leak?
Clemens Raffler clemens.raffler at gmail.com
Mon Mar 4 10:08:12 PST 2019
Dear pgrouting dev team,
I am hitting a problem with the pgr_withPoints function family and
wanted to ask you for further guidance and/or advice on how to deal with
it.
First I would like to outline  the task I am working on:
I am calculating an origin destination matrix for two sets of points
(eg. The start_points and end_points), so I am particularly interested
in retrieving the cost between each startpoint and endpoint using the
pgr_withPointsCost() function. As a cost factor I am normally using
precalculated time-costs (seconds) as cost and reverse_cost depicting
the (real) time a cyclist needs to traverse an edge (I will call those
costs real_cost). In order to model a cyclists route choice more
accurately I am introducing a multiplicator for costs on edges that seem
unpleasant to ride on. Costs on those edges get multiplied by 100 in
order to retrieve a more realistic routing output. As a result of this
extra modelling, the pgr_withPointsCost() function aggregates costs
based on the multiplied cost attributes and do not reflect the initial
time (eg. real_cost) along the path properly.
My approach to solve this problem would be to join and aggregate the
real time costs (which is stored in the input graph table) costs along
the manipulated routing output involves the use of pgr_withPoints()
function. In more detail: This function allows me to first store the
individual path elements of the routes in a result table. Then I would
like to join the real cost based on the edge attributes of the routing
output and the input graph table and group by start_pid and end_pid
while applying sum(real_cost).
But when changing the pgr_withPointsCost() function to pgr_withPoints()
function I repeatedly run into some heavy memory leakage (different
errors that seem to occur in the pgr_withPoints() function). I can give
you some details on the tests I did:
1)    Testrun with create table as pgr_withPointsCost() using a graph
with ~50000 edges, ~4000 Start and End pids: completes without errors
(although 99% of memory is used).
2)    Testrun with create table as pgr_withPoints() using a graph with
~50000 edges, ~4000 Start and End pids: ERROR std::bad_alloc Hint:
Working with directed Graph.
3)    Testrun with create table as pgr_withPoints() using a graph with
~50000 edges, 100 Start and ~4000 End pids: ERROR invalid memory alloc
request size 3474796248 Where: SQL-Funktion »pgr_withpoints«
4)    Testrun with create table as pgr_withPoints() using a graph with
~50000 edges, 10 Start and ~4000 End pids:  completes without errors (50
sec)
I checked the whole issues history of pgrouting on github and found
tests with way more startpoints (around 80000, but also using
pgr_withPointsCost() and way more RAM) – maybe it is related:
https://github.com/pgRouting/pgrouting/issues/694#issuecomment-288035720
Are you familiar with this kind of behaviour of pgr_withPoints(), which
ultimately calls just pgr_dijkstra()?  Is this a memory leak or do I
just not have enough RAM (24GB)? Do you have any hints on how to solve
this issue or do you experience similar problems? I would like to avoid
cutting the query into smaller chuncs of start_points and iterate over
them as it is very time inefficient to run such queries.
I am currently running Postgresql Version 10.3, 64 bit, PostGIS v. 2.4
and pgrouting 2.6.0, release/2.6.1.59.0 on a Windows 10, 64bit Machine
with 24GB of RAM. I will also try updating a test system to the current
postgres, postgis and pgrouting versions and run the query again.
I would be glad if you could have a look into this.
Best regards,
Clemens
More information about the pgrouting-dev mailing list
