[pgrouting-dev] pgrouting in batch mode ?
Vicky Vergara vicky at georepublic.de
Sun May 17 08:54:57 PDT 2020
Forgot to mention place of the meeting:
https://meet.jit.si/pgrouting
---------- Forwarded message ---------
Date: Sun, May 17, 2020 at 10:48 AM
Subject: Re: pgrouting in batch mode ?
To: pgRouting developers mailing list <pgrouting-dev at lists.osgeo.org>
Cc: Mahmoud Sakr <m_attia_sakr at yahoo.com>, Arthur Lesuisse <
alesuiss at gmail.com>, Esteban Zimanyi <estebanzimanyi at gmail.com>
Hello all,
MobilityDB [1] [2] will be using pgRouting to test using the benchmarks
mentioned on attached mail
[1] https://github.com/ULB-CoDE-WIT/MobilityDB
[2] https://docs.mobilitydb.com/nightly/
The Agenda for monday meeting May 18, 2pm UTC = 9am in Mexico = 7:30pm in
India will be:
- Review of work done to have travis working
- Understanding MobilityDB + pgRouting + problem description
- Discussion of a possible solution to the problem
On Sat, May 16, 2020 at 1:53 AM Esteban Zimanyi <estebanzimanyi at gmail.com>
wrote:
> Dear Vicky
> In mobility applications we need to generate data according to a given
> scenario at various scale factors to make simulations. This requires to
> send thousands of requests to pgrouting and this number of requests
> increases with the scale factor used for the generation.
> As a concrete example, the BerlinMOD data generator
> http://dna.fernuni-hagen.de/secondo/BerlinMOD/BerlinMOD.html
> uses a workweek scenario in which persons go in the morning to work,
> return back to home in the afternoon, and possibly do an extra trip after
> working hours for leisure. As another example, we described in
> https://www.mdpi.com/2220-9964/8/4/170/htm
> a scenario in which a home appliances shop needs to deliver the appliances
> to the customers and thus vehicles are loaded at a warehouse in the morning
> and spent the day delivering to the clients given a specified schedule to
> finally return back to the warehouse at the end of the day.
> We have done a first profiling of these data generators and realized that
> 87% of the time is spent in pgrouting building the graph thousands of
> times, at each query sent to pgrouting. On the other hand, the real work of
> MobilityDB only accounts for 0.11%
> [image: VirtualBox_mobilitydb-dev_13_05_2020_17_11_39 (1).png]
> For this reason we would need an API in which we build the graph once at
> the beginning of the simulation, send to pgrouting thousands of calls to
> pgr_dijkstra, pgr_aStar, pgr_dijkstraVia, etc. and then delete the graph,
> free the memory and start the simulation.
> Any idea how to achieve this ?
> Many thanks for your valuable help.
> Esteban
> Prof. Esteban Zimanyi
> Department of Computer & Decision Engineering  (CoDE) CP 165/15
> Universite Libre de Bruxelles
> Avenue F. D. Roosevelt 50
> B-1050 Brussels, Belgium
> fax: + 32.2.650.47.13
> tel: + 32.2.650.31.85
> e-mail: ezimanyi at ulb.ac.be
> Internet: http://cs.ulb.ac.be/members/esteban/
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky at georepublic.de
Web: https://georepublic.info
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20200517/9246c661/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20200517/9246c661/attachment-0001.png>
More information about the pgrouting-dev mailing list
