[pgrouting-dev] pgRouting version 3.6.0 release
Ashish Kumar ashishkr23438 at gmail.com
Fri Nov 24 01:33:12 PST 2023
Hello pgRouting community,
The pgRouting Team is pleased to announce the release of pgRouting version
3.6.0
The latest release is available at [1]
For discussions on the release, go to [2]
To see all issues & pull requests closed by this release see the Git closed
milestone for 3.6.0 on Github. [3]
*Official functions changes*
   - #2516 Standarize output pgr_aStar
      - Standarizing output columns to (seq, path_seq, start_vid, end_vid,
      node, edge, cost, agg_cost)
         - pgr_aStar (One to One) added start_vid and end_vid columns.
         - pgr_aStar (One to Many) added end_vid column.
         - pgr_aStar (Many to One) added start_vid column.
      - #2523 Standarize output pgr_bdAstar
         - pgr_bdAstar (One to One) added start_vid and end_vid columns.
         - pgr_bdAstar (One to Many) added end_vid column.
         - pgr_bdAstar (Many to One) added start_vid column.
      - #2547 Standarize output and modifying signature pgr_KSP
      - Result columns standarized to: (seq, path_id, path_seq, start_vid,
      end_vid, node, edge, cost, agg_cost)
      - pgr_ksp (One to One)
         - Added start_vid and end_vid result columns.
      - New overload functions:
         - pgr_ksp (One to Many)
         - pgr_ksp (Many to One)
         - pgr_ksp (Many to Many)
         - pgr_ksp (Combinations)
      - #2548 Standarize output pgr_drivingdistance
      - Standarizing output columns to (seq, depth, start_vid, pred, node,
         - pgr_drivingdistance (Single vertex)
            - Added depth and start_vid result columns.
         - pgr_drivingdistance (Multiple vertices)
            - Result column name change: from_v to start_vid.
            - Added depth and pred result columns.
*Proposed functions changes*
   - #2544 Standarize output and modifying signature pgr_withPointsDD
      - Signature change: driving_side parameter changed from named
      optional to unnamed compulsory driving side.
         - pgr_withPointsDD (Single vertex)
         - pgr_withPointsDD (Multiple vertices)
            - Added depth, pred and start_vid column.
            - Added depth, pred columns.
         - When details is false:
         - Only points that are visited are removed, that is, points
         reached within the distance are included
      - Deprecated signatures
         - pgr_withpointsdd(text,text,bigint,double
         precision,boolean,character,boolean)
         - pgr_withpointsdd(text,text,anyarray,double
         precision,boolean,character,boolean,boolean)
      - #2546 Standarize output and modifying signature pgr_withPointsKSP
      - Standarizing output columns to (seq, path_id, path_seq, start_vid,
      - pgr_withPointsKSP (One to One)
         - pgr_withPointsKSP (One to Many)
         - pgr_withPointsKSP (Many to One)
         - pgr_withPointsKSP (Many to Many)
         - pgr_withPointsKSP (Combinations)
         pgr_withpointsksp(text,text,bigint,bigint,integer,boolean,boolean,char,boolean)
*C/C++ code enhancements*
   - #2504 To C++ pg data get, fetch and check.
      - Stopping support for compilation with MSVC.
   - #2505 Using namespace.
   - #2512 [Dijkstra] Removing duplicate code on Dijkstra.
   - #2517 Astar code simplification.
   - #2521 Dijkstra code simplification.
   - #2522 bdAstar code simplification.
*Documentation*
   - #2490 Automatic page history links.
*SQL standarization*
   - #2555 standarize deprecated messages
   - On new internal function: do not use named parameters and default
   parameters.
*To update your database*
Download the packaged version from your operating system, and use this
command in the database:
ALTER EXTENSION pgrouting UPDATE TO "3.6.0";
[1]. https://github.com/pgRouting/pgrouting/releases/latest
[2]. https://github.com/pgRouting/pgrouting/discussions/2587
[3].
https://github.com/pgRouting/pgrouting/issues?utf8=%E2%9C%93&q=milestone%3A%22Release%203.6.0%22
Regards,
pgRouting Team.
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20231124/938a4b0c/attachment.htm>
More information about the pgrouting-dev mailing list
