[pgrouting-dev] pgRouting version 3.5.1 release
Ashish Kumar ashishkr23438 at gmail.com
Wed Sep 27 05:55:52 PDT 2023
Hello pgRouting community,
The pgRouting Team is pleased to announce the release of pgRouting version
3.5.1
The latest release is available at [1]
For discussions on the release, go to [2]
To see all issues & pull requests closed by this release, see the Git
closed milestone for 3.5.1 on Github. [3]
*Documentation fixes*
Changes on the documentation to the following:
   - pgr_degree
   - pgr_dijkstra
   - pgr_ksp
   - Automatic page history links
      - using bootstrap_version 2 because 3+ does not do dropdowns
*Issue fixes*
   - #2565: pgr_pgr_lengauerTarjanDominatorTree triggers an assertion
*SQL enhancements*
   - #2561: Not use wildcards on SQL
*pgtap tests*
   - #2559: pgtap test using sampledata
*Build fixes*
   - Fix winnie build
*Code fixes*
   - Fix clang warnings
      - Grouping headers of postgres readers
*To update your database*
Download the packaged version from your operating system, and use this
command in the database:
ALTER EXTENSION pgrouting UPDATE TO "3.5.1";
[1]. https://github.com/pgRouting/pgrouting/releases/latest
[2]. https://github.com/pgRouting/pgrouting/discussions/2571
[3].
https://github.com/pgRouting/pgrouting/issues?utf8=%E2%9C%93&q=milestone%3A%22Release%203.5.1%22
Regards,
pgRouting Team.
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20230927/e635804c/attachment.htm>
More information about the pgrouting-dev mailing list
