[pgrouting-users] directed graphs?
Stephen Woodbridge woodbri at swoodbridge.com
Sun Aug 17 12:26:38 EDT 2008
How should the directed boolean be used?
For example does function assign_vertex_id() build a directed or
undirected graph?
Does using a reverse_cost column imply a directed graph?
I assume that if I use assign_vertex_id() to build my graphs, which
appears to build undirected graphs, that I will set directed to false
and that this option would only be used if I wrote my own function the
specifically build directed graph.
-Steve
More information about the Pgrouting-users mailing list
