[pgrouting-users] problem with azimuth()
Valeria Muñoz valemunoz at gmail.com
Thu Apr 2 11:39:17 EDT 2009
Hi
 After a while I returned to my work pgrouting. I'm trying to define whether
a user should turn right or left with the function azimuth .
My problem is: does not work:) I'm doing something wrong.
My query:
A-SELECT azimuth(startpoint(the_geom),endpoint(the_geom)) as azimuth from
calle where gid = 4390
B-SELECT azimuth(startpoint(the_geom),endpoint(the_geom)) as azimuth from
calle where gid = 7326
C-SELECT azimuth(startpoint(the_geom),endpoint(the_geom)) as azimuth from
calle where gid = 4392
D-SELECT azimuth(startpoint(the_geom),endpoint(the_geom)) as azimuth from
calle where gid = 4402
 After obtaining the results:
 I compare A con B if the result is <1=turn left >1 tunr right
 I compare B con C if the result is <1=turn left >1 tunr right
 I compare C con D if the result is <1=turn left >1 tunr right
 can someone please guide me?
RG
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20090402/53f04623/attachment.html
More information about the Pgrouting-users mailing list
