[pgrouting-users] Boost CHAR_BIT Error
Inde Brasil mailing at indebrasil.com
Tue Apr 14 15:19:20 EDT 2009
Guys,
I'm installing PgRouting in a Debian Lenny box. I ran cmake command
successfully but when i execute make command i get this:
[ 16%] Building CXX object core/src/CMakeFiles/routing.dir/boost_wrapper.o
In file included from /usr/include/c++/4.3/ext/hash_set:64,
                 from /usr/include/boost/graph/adjacency_list.hpp:22,
                 from /usr/local/pgrouting/core/src/boost_wrapper.cpp:25:
/usr/include/c++/4.3/backward/backward_warning.h:33:2: warning: #warning
This file includes at least one deprecated or antiquated header which may be
removed without further notice at a future date. Please use a non-deprecated
interface with equivalent functionality instead. For a listing of
replacement headers and interfaces, consult the file backward_warning.h. To
disable this warning use -Wno-deprecated.
/usr/include/boost/graph/dijkstra_shortest_paths.hpp:19,
                 from /usr/local/pgrouting/core/src/boost_wrapper.cpp:26:
/usr/include/boost/pending/relaxed_heap.hpp: In member function ‘size_t
boost::relaxed_heap<IndexedType, Compare, ID>::log_base_2(size_t)’:
/usr/include/boost/pending/relaxed_heap.hpp:101: error: ‘CHAR_BIT’ was not
declared in this scope
make[2]: ** [core/src/CMakeFiles/routing.dir/boost_wrapper.o] Erro 1
make[1]: ** [core/src/CMakeFiles/routing.dir/all] Erro 2
make: ** [all] Erro 2
I found some references about this problem (
http://pgrouting.postlbs.org/ticket/138), but no solution.
My boost version is 1.34.1-14.
Could you help me ?
Thanks so far.
Tadeu Granemann - INDE Brasil
http://www.indebrasil.com
contato at indebrasil.com
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20090414/c7f0b170/attachment.html
More information about the Pgrouting-users mailing list
