[pgrouting-users] Boost CHAR_BIT Error
Stephen Woodbridge woodbri at swoodbridge.com
Tue Apr 14 17:15:53 EDT 2009
Just added workaround to the ticket:
http://pgrouting.postlbs.org/ticket/138#comment:4
-Steve
Inde Brasil wrote:
> Guys,
> I'm installing PgRouting in a Debian Lenny box. I ran cmake command
> successfully but when i execute make command i get this:
> [ 16%] Building CXX object core/src/CMakeFiles/routing.dir/boost_wrapper.o
> In file included from /usr/include/c++/4.3/ext/hash_set:64,
>                  from /usr/include/boost/graph/adjacency_list.hpp:22,
>                  from /usr/local/pgrouting/core/src/boost_wrapper.cpp:25:
> /usr/include/c++/4.3/backward/backward_warning.h:33:2: warning: #warning
> This file includes at least one deprecated or antiquated header which
> may be removed without further notice at a future date. Please use a
> non-deprecated interface with equivalent functionality instead. For a
> listing of replacement headers and interfaces, consult the file
> backward_warning.h. To disable this warning use -Wno-deprecated.
> /usr/include/boost/graph/dijkstra_shortest_paths.hpp:19,
>                  from /usr/local/pgrouting/core/src/boost_wrapper.cpp:26:
> /usr/include/boost/pending/relaxed_heap.hpp: In member function ‘size_t
> boost::relaxed_heap<IndexedType, Compare, ID>::log_base_2(size_t)’:
> /usr/include/boost/pending/relaxed_heap.hpp:101: error: ‘CHAR_BIT’ was
> not declared in this scope
> make[2]: ** [core/src/CMakeFiles/routing.dir/boost_wrapper.o] Erro 1
> make[1]: ** [core/src/CMakeFiles/routing.dir/all] Erro 2
> make: ** [all] Erro 2
> I found some references about this problem
> (http://pgrouting.postlbs.org/ticket/138), but no solution.
> My boost version is 1.34.1-14.
> Could you help me ?
> Thanks so far.
> Tadeu Granemann - INDE Brasil
> http://www.indebrasil.com
> contato at indebrasil.com <mailto:contato at indebrasil.com>
> Pgrouting-users mailing list
> Pgrouting-users at lists.postlbs.org
> http://lists.postlbs.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
