[pgrouting-users] New workshop
Daniel Kastl kastl at orkney.co.jp
Thu Apr 23 21:38:37 EDT 2009
Hi Kai,
Thank you for the nice work!
As time allows I will try it out and see how it works.
While I'm very curious what http://www.kneipenculture.de is going to become
in the future, I'm a little bit worrying about link consistency. Would be
too bad if links would be broken in the future.
Probably TRAC isn't the best choice for tasks like this, but the way
OpenLayers of Mapserver go with their documentation creation might be a bit
overkill for pgROuting, I think.
Maybe one possibility would be to create a "documentation" directory in SVN
and give access to you and others, who help with documentation, so at least
someone could upload files there and link to them then in TRAC.
Any better idea?
Daniel
2009/4/22 Kai Behncke <Kai-Behncke at gmx.de>
> Dear users,
> as posted some days ago a new workshop (OL 2.7, own osm-data (evaluating
> them in UMN)) has been finished. You find it at:
> http://pgrouting.postlbs.org/wiki/WorkshopOL2.7andOSM
> Best regards, Kai Behncke
> -------- Original-Nachricht --------
> > Datum: Mon, 20 Apr 2009 13:53:44 +0200
> > Von: "Kai Behncke" <Kai-Behncke at gmx.de>
> > An: pgrouting-users at lists.postlbs.org
> > Betreff: Re: [pgrouting-users] PgRouting-Problems with own OSM-data
> > Dear users,
> > it works now. I made an extract of osm-data (with osmosis) and used then
> > osm2pgrouting.
> > Everything excellent now (I haven`t got any clue why it didn`t work with
> > the shapefile and
> > shp2pgrouting).
> > I`m going to start the workshop (with describing difficulties and so on)
> > today at:
> > There will be also a section about the data-problem.
> > thank you very much for the support.
> > Best regards, Kai
> > > Datum: Mon, 20 Apr 2009 09:49:19 +0200
> > > An: Anton Patrushev <anton at orkney.co.jp>,
> > > Hi Anton,
> > > I will put it in the Wiki in a couple of hours.
> > > Indeed it`s a really interesting topic because meanwhile I found out
> > that
> > > there a less failures if I take OSM-XML and use osm2pgrouting (the data
> > > with the many, many failures were taken from out of a shape via
> > shp2pgsql)  ,
> > > I will do some more tests and set it in the wiki in the afternoon.
> > > Best regards, Kai
> > > > Datum: Mon, 20 Apr 2009 10:50:47 +0900
> > > > Von: Anton Patrushev <anton at orkney.co.jp>
> > > > Kai, Steve,
> > > > It sounds like a very good example of data validation and for sure
> > > > will be interesting for other users.
> > > > Can someone of you please put it to pgRouting wiki?
> > > > Anton.
> > > > On Sat, Apr 18, 2009 at 8:25 PM, Kai Behncke <Kai-Behncke at gmx.de>
> > wrote:
> > > > > Dear users,
> > > > > maybe the following screenshot helps fo find out what is wrong with
> > my
> > > > geodata:
> > > > > http://www.selbstverwaltung-bundesweit.de/weird_numbers.png
> > > > > The three numbers (blcak on grey backround) show the gid of the
> > > > geometry,the source-id and the target-id.
> > > > > The blue figure shows the id of the vertices (no dead end) and the
> > red
> > > > number is the number of the dead-end-vertices.
> > > > > As you cann see some are correct and some are not.
> > > > > This should happen at SELECT assign_vertex_id('my_table', 0.001,
> > > > 'the_geom', 'gid');
> > > > > ....but why? I cant`t see the system of that failure?
> > > > > Best regards, Kai
> > > > >> Datum: Sat, 18 Apr 2009 00:57:30 +0200
> > > > >> An: Stephen Woodbridge <woodbri at swoodbridge.com>,
> OSM-data
> > > > >> Hi Stephen, Hi mailinglist,
> > > > >> thank you very much for that hint. With that way I was able to
> find
> > > out
> > > > >> that there are far too many "dead ends" in my data, so I think
> this
> > > is
> > > > the
> > > > >> proof that it`s really a data problem?
> > > > >> http://www.selbstverwaltung-bundesweit.de/too_many_dead_ends.png
> > > > >> I made this test also with the victoria-data, there everything is
> > > > correct.
> > > > >> To get a step further I work now with a very small dataset (just
> 35
> > > > >> geometries) (as you can see in the screenshot above) but without
> > > > success
> > > > >> so far.
> > > > >> >If you have a lot of red dots between segments
> > > > >> >that should be joined, you probably need to rebuild your vertices
> > > tmp
> > > > >> >table with a larger tolerance.
> > > > >> I did that, I changed 0.001 in
> > > > >> SELECT assign_vertex_id('auswahl_os', 0.001, 'the_geom', 'gid');
> > > > >> with the values 0.005, 0.01, 0.05, 0.5, 5, 50 and so on
> > > > >> The values <50 still show very many "dead ends". If I have higher
> > > > values
> > > > >> then
> > > > >> the amount of vertices in general decreases, so a routing is also
> > not
> > > > >> possible anymore, you can see it here:
> > > > >> http://www.selbstverwaltung-bundesweit.de/not_enough_vertices.png
> > > > >> Maybe the following is a hint:
> > > > >> If I use
> > > > >> with my data I get 54 entries in the vertices_tmp-table.
> > > > >> (an extract of the victorie-data (50 geometries) just gives 42
> > > entries
> > > > in
> > > > >> vertices_tmp).
> > > > >> What could be the reason that I get so many entries mith my data?
> > > > >> What exactly stands the value 0.001 for?
> > > > >> I really don`t understand what could be wrong with my geodata :-(
> > > > >> Might it be possible that someone would have a look to these 54
> > > > geometries
> > > > >> (4 eyes see more than two) ??
> > > > >> Puh....if I get it I will really write a huge tutorial in the
> > > > >> pgrouting-wiki.
> > > > >> Best regards, Kai
> > > > >> > Datum: Wed, 15 Apr 2009 13:24:21 -0500
> > > > >> > Von: Stephen Woodbridge <woodbri at swoodbridge.com>
> > > > >> > An: Kai Behncke <Kai-Behncke at gmx.de>
> > > > >> > CC: pgrouting-users at lists.postlbs.org
> > OSM-data
> > > > >> > Kai,
> > > > >> > First off you probably need to build some diagnostic tools to
> > help
> > > > you
> > > > >> > understand the problem better, especially to help you determine
> > if
> > > it
> > > > is
> > > > >> > a data problem. I find two tools that are easy to build and help
> > a
> > > > lot.
> > > > >> > You can see them in action here:
> > > > >> > http://imaptools.com/leaddog/routing/dd.html
> > > > >> > Zoom into a city, open the layerswitcher and select "Just the
> > > > Streets"
> > > > >> > and "Dead Ends"
> > > > >> > 1) create a mapfile that displays the street segments from the
> > > > routing
> > > > >> > database and add this as an optional base layer. You might want
> > to
> > > > add
> > > > >> > color oneway streets a different color, but in general keep the
> > > > display
> > > > >> > simple and probably single pixel lines. You might label the
> > > segments
> > > > >> > with their UID so you can go back to the database and query them
> > in
> > > > >> > detail.
> > > > >> > 2) add a column cnt integer to the vertices_tmp table and update
> > it
> > > > with
> > > > >> > the count of segments that reference that node. Maybe something
> > > like
> > > > >> this:
> > > > >> > alter table vertices_tmp add column cnt integer;
> > > > >> > update vertices_tmp set cnt=0;
> > > > >> > update vertices_tmp set cnt=cnt+1 where streets.source=id;
> > > > >> > update vertices_tmp set cnt=cnt+1 where streets.target=id;
> > > > >> > Now create a mapfile layer for points and display the
> > vertices_tmp
> > > > >> > LAYER
> > > > >> >    NAME "deadends"
> > > > >> >    TYPE POINT
> > > > >> >    CONNECTIONTYPE "postgis"
> > > > >> >    CONNECTION ...
> > > > >> >    DATA ...
> > > > >> >    CLASSEXPRESSION "cnt"
> > > > >> >    CLASS
> > > > >> >      EXPRESSION "cnt=1"
> > > > >> >      STYLE
> > > > >> >        SYMBOL "circle"
> > > > >> >        SIZE 5
> > > > >> >        COLOR 255 0 0
> > > > >> >      END
> > > > >> >    END
> > > > >> >    CLASS
> > > > >> >      EXPRESSION "cnt>2"
> > > > >> >      STYLE
> > > > >> >        SYMBOL "circle"
> > > > >> >        SIZE 3
> > > > >> >        COLOR 0 255 0
> > > > >> >      END
> > > > >> >    END
> > > > >> > END
> > > > >> > This will display red dots at dead ends and green dots as good
> > > > >> > connections be segments. If you have a lot of red dots between
> > > > segments
> vertices
> > > tmp
> > > > >> > It is very hard to debug a large black box like a router without
> > > > having
> > > > >> > some tools that can give you some better insight as to what is
> > > going
> > > > on.
> > > > >> > -Steve
> > > > >> Neu: GMX FreeDSL Komplettanschluss mit DSL 6.000 Flatrate +
> > > > >> Telefonanschluss für nur 17,95 Euro/mtl.!*
> > http://dslspecial.gmx.de/freedsl-surfflat/?ac=OM.AD.PD003K11308T4569a
> > > > >> _______________________________________________
> > > > >> Pgrouting-users mailing list
> > > > >> Pgrouting-users at lists.postlbs.org
> > > > >> http://lists.postlbs.org/mailman/listinfo/pgrouting-users
> > > > > Psssst! Schon vom neuen GMX MultiMessenger gehört? Der kann`s mit
> > > > allen: http://www.gmx.net/de/go/multimessenger01
> > allen:
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20090424/90c651f0/attachment.html
More information about the Pgrouting-users mailing list
