[pgrouting-users] osm2pgrouting: errors on importing routing_core.sql
Kai Behncke Kai-Behncke at gmx.de
Mon Aug 17 16:58:13 EDT 2009
Hi Frank,
a couple of month ago I had some troubles to install pgrouting on Debian Lenny,
we solved the problem like that:
http://pgrouting.postlbs.org/discussion/topic/269
A bit "quirlywirly", so try it better as last way :-)
Best regards, Kai
-------- Original-Nachricht --------
> Datum: Mon, 17 Aug 2009 22:00:11 +0200
> Von: "Frank Glück" <frankimglueck at gmx.de>
> An: "\'Daniel Kastl\'" <kastl at orkney.co.jp>, "\'pgRouting Users List\'" <pgrouting-users at lists.postlbs.org>
> Betreff: Re: [pgrouting-users] osm2pgrouting:	errors	on	importing	routing_core.sql
> Hi Daniel,
> sorry for answering so late.
> Daniel Kastl wrote:
> >Frank Glück schrieb:
> >>> You need to have pgRouting successfully installed.
> >>> And this doesn't seem to be the case.
> >> Oops, that's it. ;-)
> >> Ok, I now followed the instructions at
> >> http://pgrouting.postlbs.org/wiki/1.x/InstallationUbuntu904. But on
> doing
> >> 	cmake -DWITH_TSP=ON -DWITH_DD=ON .
> >> I got the error "-- PostgreSQL not found."
> >> What's going wrong here? I definetely have installed PostgreSQL before,
> >> because I already use it since weeks. Is there still any path anywhere
> >which
> >> I have to adjust therefore?
> >> Thank you for helping me!
> >> Greetings, Frank
> >Frank, do you have also installed the "devel" package of PostgreSQL?
> No, should I? - I only have installed postgresql-8.3.
> Thank you!
> Frank
> Pgrouting-users mailing list
> Pgrouting-users at lists.postlbs.org
> http://lists.postlbs.org/mailman/listinfo/pgrouting-users
GRATIS für alle GMX-Mitglieder: Die maxdome Movie-FLAT!
Jetzt freischalten unter http://portal.gmx.net/de/go/maxdome01
More information about the Pgrouting-users mailing list
