[pgrouting-users] osm2pgrouting import problem
Jaak Laineste (Nutiteq) jaak at nutiteq.com
Thu Aug 27 10:10:30 EDT 2009
Hello,
  I'm trying to do exactly same as Kai, with Germany.osm (6.4G). I
applied last osm2pgrouting patch without obvious errors (tried also
http://pgrouting.postlbs.org/ticket/161 but this gave patch errors), I
did make and tried import. My current result was same as without
patch: last message is "Trying to parse data" and it stops
immediately. It seems to work with some other, much smaller osm file.
I have 512M in my (virtual) machine, could this be a problem?
Or maybe someone is ready to share ready DB dump for Germany ? I just
need table "ways" for some experiments.
Thank you!
/Jaak Laineste
> Dear users,
> The amount of roads,ways,tracks,footways is the same (with patch or without patch).
> but the way I did I get unfortunately wrong results (you can see it in the screenshot in the attachment).
> Maybe I did something wrong?
> Well, integrating the patch worked, but I`m not sure how to use
> "osm2pgrouting-with-the-patch" then?
> As I said: If I don`t have the table-structure (nodes ....etc.)
> I get a couple of errors while doing:
> "./osm2pgrouting -file your-OSM-XML-File.osm -conf mapconfig.xml -dbname routing -user postgres"
> If I have the table-structure data are written in (but in that case with wrong vertices)
> (I made the tests described here:
> http://pgrouting.postlbs.org/wiki/Understandingandtestingthedata )
> Has anybody an idea what could be the reason?
> Thank you very much, Kai
> -------- Original-Nachricht --------
>> Datum: Wed, 15 Jul 2009 14:46:30 +0200
>> Von: "Kai Behncke" <Kai-Behncke at gmx.de>
>> An: pgrouting-users at lists.postlbs.org
>> Betreff: Re: [pgrouting-users] osm2pgrouting import problem
>> I have tried the patch now while the table-structure existed alredy
>> (emplty tables):
>> http://www.kneipenculture.de/database.png
>> That time it worked well and I got routing-data in the database, but far
>> less then I had without the patch
>> (without the patch I had 16300 ways, with the patch I have 9000 ways) (I
>> tested it with the osm-data of the City "Osnabrueck").
>> Might it be that only special types are transformed?
>> I will try to analyze what makes the difference.......
>> > Datum: Wed, 15 Jul 2009 14:22:03 +0200
>> > An: Vladislav Shikhov <vladshikhov at gmail.com>,
>> > Hi Vladislay, Hi Stephen,
>> > thank you for your patient help.
>> > Well, I nearly got it.
>> > The following steps:
>> > > 1. svn checkout -r 334
>> > > http://pgrouting.postlbs.org/svn/pgrouting/tools/osm2pgrouting/trunk
>> > > osm2pgrouting
>> > > 2. copy someway a patch from this email into osm2pgrouting just
>> created
>> > > 3. cd into osm2pgrouting
>> > > 4. patch -p0 -i db.patch
>> > > 5. make
>> > .....work well.
>> > I have created a database with pg_routing-functions (so far it has the
>> > tables spatial_ref_sys and geometry_columns), but when
>> > I start:
>> > I get many error-messages like:
>> > Reference nd=57017125 has no corresponding Node Entry (Maybe Node entry
>> > after Reference?)
>> > ERROR:  relation "nodes" does not exist
>> > STATEMENT:  SELECT id,lon,lat FROM nodes WHERE id ='57017123';
>> > SELECT id,lon,lat FROM nodes WHERE id ='57017123'; ERROR:  relation
>> > Reference nd=57017123 has no corresponding Node Entry (Maybe Node entry
>> > after Reference?)
>> > STATEMENT:  SELECT id,lon,lat FROM nodes WHERE id ='57017127';
>> > LOG:  unexpected EOF on client connection
>> > Do I need a special table-structure in the db to start the patch
>> > succesfully?
>> > Thank you again, Kai
>> > Jetzt kostenlos herunterladen: Internet Explorer 8 und Mozilla Firefox 3
>> > sicherer, schneller und einfacher! http://portal.gmx.net/de/go/atbrowser
>> > _______________________________________________
>> > Pgrouting-users mailing list
>> > Pgrouting-users at lists.postlbs.org
>> > http://lists.postlbs.org/mailman/listinfo/pgrouting-users
>> Neu: GMX Doppel-FLAT mit Internet-Flatrate + Telefon-Flatrate
>> f?r nur 19,99 Euro/mtl.!* http://portal.gmx.net/de/go/dsl02
> -------------- next part --------------
> A non-text attachment was scrubbed...
> Type: image/png
> Desc: not available
> Url : http://lists.postlbs.org/pipermail/pgrouting-users/attachments/20090715/13774bec/attachment.png
> End of Pgrouting-users Digest, Vol 11, Issue 11
Jaak Laineste
www.nutiteq.com
Skype: jaakl3000
Mobile: +372 509 2586
More information about the Pgrouting-users mailing list
