[pgrouting-users] problem with pgrouting.
Valeria Muñoz valemunoz at gmail.com
Wed Feb 4 10:19:33 EST 2009
Stephen you are right i change to :
SELECT assign_vertex_id('edges', 0.000001, 'the_geom', 'gid');
 and works!!! thanks!!
2009/2/4 Stephen Woodbridge <woodbri at swoodbridge.com>
> Valeria,
> What projection is your shapefile in? it looks like WGS84 or NAD83 from
> your coordinates below. So when you did:
> SELECT assign_vertex_id('edges', 0.001, 'the_geom', 'gid');
> you should probably have done:
> The tolerance needs to be in the units of your data. This will probably
> give better results.
> You should probably drop the database and start over with a new load and
> use the statement above when you get to that step.
> -Steve
> Valeria Muñoz wrote:
>>  Hi
>>  I followed a little tutorial works perfectly with the shapefile from the
>> example, but to use mine the result is not expected, generating lines are
>> not continuous, I think I missing some coordinates or something to work with
>> my shapefile.
>>  tutorial url
>> http://www.utdallas.edu/~ama054000/rt_tutorial.html
>>  query:
>>  the query is optimal path between 887 y 852. :
>> SELECT rt.gid, AsText(rt.the_geom) AS wkt,
>>                   length(rt.the_geom) AS length, calle.gid
>>                FROM calle,
>>                    (SELECT gid, the_geom
>>                        FROM dijkstra_sp_delta(
>>                            'calle',
>>                            887,
>>                            852,
>>                            3000)
>>                     ) as rt
>>                WHERE calle.gid=rt.gid;
>> result:
>>  "gid";"wkt";"length";"gid"
>> 4389;"MULTILINESTRING((-71.1951327440651
>> -30.5911350429583,-71.1957462426904 -30.5912128948402,-71.1957861853043
>> -30.591219747929,-71.1958400125164
>> -30.591211719682))";0.000713367403530106;4389
>> 4603;"MULTILINESTRING((-71.1939954028678
>> -30.5921681162637,-71.1939834234752 -30.5922241673576,-71.1938231446269
>> -30.5925509466888))";0.000421286769021393;4603
>> 4331;"MULTILINESTRING((-71.1950174992082
>> -30.5919506007811,-71.1950526139385
>> -30.5916919152203))";0.000261057969957178;4331
>> 4608;"MULTILINESTRING((-71.1938231446269
>> -30.5925509466888,-71.1937648360013
>> -30.5926358138883))";0.00010296765211197;4608
>> RG
>> attached image.
>>  please help!!..
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.postlbs.org
>> http://lists.postlbs.org/mailman/listinfo/pgrouting-users
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20090204/415917d1/attachment.html
More information about the Pgrouting-users mailing list
