[pgrouting-users] directions problem
Valeria Muñoz valemunoz at gmail.com
Fri Feb 13 08:19:12 EST 2009
hi daniel
  i did try with Shooting*  and WORKS!!! .. thanks thanks!!... now my next
problem :) i am using azimuth() for instructions(turn left right etc..) but
i do not how use it, can you help me please?
RG
Query :
SELECT azimuth(startpoint(the_geom),endpoint(the_geom)) as azimuth from
calle where gid = ".$id_gid."
I read in a foro about azimuth() and this says that the result i have to
multiply by 57.29577951. The result is the angle. Now How i know if the user
have to turn left or rigth ..etc?, exist some algoritm? or function?
RG
2009/2/12 Daniel Kastl <kastl at orkney.co.jp>
> Hi Valeria,
> When I saw your first screenshot I already guessed that the first
> segment seems to be the problem, but you already could confirm this.
> What if you try it with Shooting* function once. It routes from link to
> link and not from node to node. (So you need to use link ID's as start
> and end in the function.)
> Daniel
> Valeria Muñoz schrieb:
> > I found my problem, the problem is the first segment, from the
> > beginning. Query does not consider the first segment, so I took the
> > gid of the segment and obtained the information for route instructions.
> > As a result of the query do not delivery me the first segment (in some
> > cases)  not consider if is one-way street.
> > so, now my problem is the first segment. how can i bind to the
> > function to return the first segment informacion for the route?
> > please see the atachment
> > RG
> > PD:sorry for my english :)
> > 2009/2/12 Valeria Muñoz <valemunoz at gmail.com <mailto:valemunoz at gmail.com
> >     I exchanged values,
> >     update calle set reverse_cost=reverse_cost + 1000000 WHERE oneway=1;
> >     update calle set to_cost=to_cost + 1000000 WHERE oneway=-1;
> >     please see the atachment img_01
> >     update calle set reverse_cost=reverse_cost + 1000000 WHERE oneway=-1;
> >     update calle set to_cost=to_cost + 1000000 WHERE oneway=1;
> >     please see the atachment img_02
> >     RG
> >     2009/2/12 Stephen Woodbridge <woodbri at swoodbridge.com
> >     <mailto:woodbri at swoodbridge.com>>
> >         Well, maybe I got the from-to sense backwards. Does it always
> >         route the wrong-way down all one-way streets now? If so then,
> >         swap the 1 and -1 in the update statements.
> >         -Steve
> >         Valeria Muñoz wrote:
> >             Stephen
> >              does not work, please see the attachment
> >             RG
> >             <mailto:woodbri at swoodbridge.com>>>
> >                So set reverse_cost when oneway=1 and cost when oneway=-1
> >                Since you have already messed with the values I would
> >             do this now:
> >                -- make sure everything is re-initiallized
> >                UPDATE calle SET to_cost=length(the_geom),
> >                reverse_cost=length(the_geom);
> >                -- update the oneway costs
> >             WHERE oneway=1;
> >                update calle set cost=cost + 1000000 WHERE oneway=-1;
> >                vacuum analyze calle;
> >                Now see how your test route looks.
> >                -Steve
> >                    hi Stephen
> >                     i got
> >                     "oneway";"count"
> >                    -1;1451
> >                    0;21403
> >                    1;2640
> >                      0=both ways
> >                    -1=B->A
> >                    1= A->B
> >                     RG.
> >             <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>
> >             <mailto:woodbri at swoodbridge.com>>>>
> >                       Valeria,
> >                       What do you get for this query:
> >                       select distinct oneway, count(*) as count from
> >             calle group by
> >                       oneway, order by oneway;
> >                       If you have a street A------->B then the oneway
> >             flag probable
> >                    needs
> >                       3 values. 0 for both ways, 1? for A to B, and
> >             maybe 2? for B
> >                    to A.
> >                       You need to figure out which values are which.
> >                       Then you need cost or reverse cost based on the
> >             value of oneway.
> >                       -Steve
> >                           hi Daniel, thanks for the link..
> >                            I did the following:
> >                            * UPDATE calle SET to_cost=length(the_geom),
> >                           reverse_cost=length(the_geom); *
> >                           * UPDATE calle SET reverse_cost=reverse_cost
> >             + 1000000 WHERE
> >                           oneway!=0 ,  oneway!=0 are one way streets. *
> >                           my query:
> >                                   SELECT edge_id as gid,cost as length
> >             FROM
> >                           shortest_path_astar('SELECT gid AS
> >             id,source::int4,
> >                           target::int4, to_cost::double precision as
> cost,
> >                           reverse_cost::double precision, x1,y1,x2,y2
> FROM
> >                           calle',3412,3411,false,true)**
> >                            this do not works 100%, with some street
> >             works with
> >                    others no...
> >                            I am missing something?
> >                            RG
> >                           2009/2/11 Daniel Kastl <kastl at orkney.co.jp
> >             <mailto:kastl at orkney.co.jp>
> >                    <mailto:kastl at orkney.co.jp <mailto:kastl at orkney.co.jp
> >             <mailto:kastl at orkney.co.jp> <mailto:kastl at orkney.co.jp
> >             <mailto:kastl at orkney.co.jp>>>
> >             <mailto:kastl at orkney.co.jp>>>>>
> >                              So I guess pgRouting doesn't know that
> >             there is a one
> >                    way street.
> >                              You might want to read this:
> >              http://pgrouting.postlbs.org/wiki/OneWayStreets
> >                              Daniel
> >                               > HI!!
> >                               >       I have a little problem with my
> >             routing, the best
> >                           path from
> >                              A to
> >                               > B do not respect the traffic direction.
> >                               > attached image.
> >                               > please check in the example vicente
> >             perez rosales
> >                    street
> >                               > Query
> >                               > rt.gid,rt.the_geom AS tg,
> >             AsText(rt.the_geom) AS wkt,
> >                               > length(rt.the_geom) AS length,
> >             calle.gid FROM calle,
> >                           (SELECT gid,
> >                               > the_geom FROM dijkstra_sp_delta(
> >             'calle', 3414, 3406,
> >                           3000) ) as rt
> >                               > WHERE calle.gid=rt.gid;
> >                               > RG
> >             _______________________________________________
> >                               > Pgrouting-users mailing list
> >                               > Pgrouting-users at lists.postlbs.org
> >             <mailto:Pgrouting-users at lists.postlbs.org>
> >             <mailto:Pgrouting-users at lists.postlbs.org>>
> >             <mailto:Pgrouting-users at lists.postlbs.org>>>
> >             <mailto:Pgrouting-users at lists.postlbs.org>>>>
> >              http://lists.postlbs.org/mailman/listinfo/pgrouting-users
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20090213/d37a2c5f/attachment.html
More information about the Pgrouting-users mailing list
