[pgrouting-users] osm2pgrouting import problem
Vladislav Shikhov vladshikhov at gmail.com
Sun Jul 12 13:51:32 EDT 2009
I've made some trivial patches for osm2pgrouting, so now it takes
about 4 hours to import whole Russia in to DB on 2 cores 2.3 Ghz
Athlon &1 Gb memory. Switch on you brain, it rather simple.
On Sun, Jul 12, 2009 at 3:59 PM, Kai Behncke<Kai-Behncke at gmx.de> wrote:
> Dear users,
> I tried it as well with the Germany-osm-data (600 MB) on a pc with
> 4 processors, 4 GB RAM and 7GB Swap), but it failed after 14 hours.
> I trief then to load in single counties (Bundesländer). Always the first one works
> but after that (e.g. first one is "Hamburg", second one "Bremen") only nodes are inserted (and no ways). Is this a known error/issue.
> What would you recommend to get All the data of one country in a database?
> Thank you very much, Kai
> -------- Original-Nachricht --------
>> Datum: Mon, 29 Jun 2009 09:35:45 +0900
>> Von: Daniel Kastl <kastl at orkney.co.jp>
>> An: pgrouting-users at lists.postlbs.org
>> Betreff: Re: [pgrouting-users] osm2pgrouting import problem
>> Hi Eike,
>> You probably run into this issue: http://pgrouting.postlbs.org/ticket/140
>> If you can try it with a smaller dataset for testing and it worked, then
>> this is the case. If it still doesn't work then please let us know.
>> The original author of osm2pgrouting said he's currently working on this
>> issue as time allows.
>> Daniel
>> PS: Once I tried a little larger dataset I just increased my SWAP
>> partition and it worked then, but I don't know how large the German data
>> is. It's not a nice solution anyway.
>> Eike Lüders schrieb:
>> > Hello everybody!
>> > I've got a problem with osm2pgrouting.
>> > I downloaded the osm file for germany from here:
>> > http://download.geofabrik.de/osm/europe/germany.osm.bz2
>> > If I try to run osm2pgrouting on it now by typing
>> > ./osm2pgrouting -file germany.osm -conf mapconfig.xml -dbname routing
>> > -user postgres -passwd postgres -clean
>> > into the shell it gives me the following information, but nothing
>> > happes (the db information above are correct!).
>> > There is no error message or something like that.
>> > I hope anybody know how to solve this problem.
>> > host=127.0.0.1 user=postgres dbname=routing port=5432 password=postgres
>> > connection success
>> > Trying to load config file mapconfig.xml
>> > Trying to parse config
>> > SE for <configuration>
>> > SE for <type>
>> > SE for <class>
>> > class name = motorway
>> > class id = 101
>> > class id = 101 name = motorway added to type name=highway
>> > SE for <class>
>> > class name = motorway_link
>> > class id = 102
>> > class id = 102 name = motorway_link added to type name=highway
>> > SE for <class>
>> > class name = motorway_junction
>> > class id = 103
>> > class id = 103 name = motorway_junction added to type name=highway
>> > SE for <class>
>> > class name = trunk
>> > class id = 104
>> > class id = 104 name = trunk added to type name=highway
>> > SE for <class>
>> > class name = trunk_link
>> > class id = 105
>> > class id = 105 name = trunk_link added to type name=highway
>> > SE for <class>
>> > class name = primary
>> > class id = 106
>> > class id = 106 name = primary added to type name=highway
>> > SE for <class>
>> > class name = primary_link
>> > class id = 107
>> > class id = 107 name = primary_link added to type name=highway
>> > SE for <class>
>> > class name = secondary
>> > class id = 106
>> > class id = 106 name = secondary added to type name=highway
>> > SE for <class>
>> > class name = tertiary
>> > class id = 107
>> > class id = 107 name = tertiary added to type name=highway
>> > SE for <class>
>> > class name = residential
>> > class id = 107
>> > class id = 107 name = residential added to type name=highway
>> > SE for <class>
>> > class name = living_street
>> > class id = 108
>> > class id = 108 name = living_street added to type name=highway
>> > SE for <class>
>> > class name = service
>> > class id = 109
>> > class id = 109 name = service added to type name=highway
>> > SE for <class>
>> > class name = track
>> > class id = 110
>> > class id = 110 name = track added to type name=highway
>> > SE for <class>
>> > class name = pedestrian
>> > class id = 111
>> > class id = 111 name = pedestrian added to type name=highway
>> > SE for <class>
>> > class name = services
>> > class id = 112
>> > class id = 112 name = services added to type name=highway
>> > SE for <class>
>> > class name = bus_guideway
>> > class id = 113
>> > class id = 113 name = bus_guideway added to type name=highway
>> > SE for <class>
>> > class name = path
>> > class id = 114
>> > class id = 114 name = path added to type name=highway
>> > SE for <class>
>> > class name = cicleway
>> > class id = 115
>> > class id = 115 name = cicleway added to type name=highway
>> > SE for <class>
>> > class name = footway
>> > class id = 116
>> > class id = 116 name = footway added to type name=highway
>> > SE for <class>
>> > class name = bridleway
>> > class id = 117
>> > class id = 117 name = bridleway added to type name=highway
>> > SE for <class>
>> > class name = byway
>> > class id = 118
>> > class id = 118 name = byway added to type name=highway
>> > SE for <class>
>> > class name = steps
>> > class id = 119
>> > class id = 119 name = steps added to type name=highway
>> > SE for <class>
>> > class name = unclassified
>> > class id = 100
>> > class id = 100 name = unclassified added to type name=highway
>> > SE for <class>
>> > class name = road
>> > class id = 100
>> > class id = 100 name = road added to type name=highway
>> > SE for <type>
>> > SE for <class>
>> > class name = lane
>> > class id = 201
>> > class id = 201 name = lane added to type name=cycleway
>> > SE for <class>
>> > class name = track
>> > class id = 202
>> > class id = 202 name = track added to type name=cycleway
>> > SE for <class>
>> > class name = opposite_lane
>> > class id = 203
>> > class id = 203 name = opposite_lane added to type name=cycleway
>> > SE for <class>
>> > class id = 204
>> > class id = 204 name = opposite added to type name=cycleway
>> > SE for <type>
>> > SE for <class>
>> > class name = grade1
>> > class id = 301
>> > class id = 301 name = grade1 added to type name=tracktype
>> > SE for <class>
>> > class name = grade2
>> > class id = 302
>> > class id = 302 name = grade2 added to type name=tracktype
>> > SE for <class>
>> > class name = grade3
>> > class id = 303
>> > class id = 303 name = grade3 added to type name=tracktype
>> > SE for <class>
>> > class name = grade4
>> > class id = 304
>> > class id = 304 name = grade4 added to type name=tracktype
>> > SE for <class>
>> > class name = grade5
>> > class id = 305
>> > class id = 305 name = grade5 added to type name=tracktype
>> > SE for <type>
>> > SE for <class>
>> > class name = roundabout
>> > class id = 401
>> > class id = 401 name = roundabout added to type name=junction
>> > Trying to load data
>> > Trying to parse data
>> > Kind regards
>> > Eike Lüders
>> > _______________________________________________
>> > Pgrouting-users mailing list
>> > Pgrouting-users at lists.postlbs.org
>> > http://lists.postlbs.org/mailman/listinfo/pgrouting-users
> Neu: GMX Doppel-FLAT mit Internet-Flatrate + Telefon-Flatrate
> für nur 19,99 Euro/mtl.!* http://portal.gmx.net/de/go/dsl02
More information about the Pgrouting-users mailing list
