[pgrouting-users] Why does shooting star return the last segment twice?
Anton Patrushev anton at orkney.co.jp
Sun May 10 20:16:32 EDT 2009
Hi Steve,
No, it doesn't - the starting edge should always be returned. At least once :)
Are you using the latest version?
Anton.
On Sat, May 9, 2009 at 3:40 AM, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
> Anton,
> Does this also explain why the starting segment is NOT returned?
> Notice below that the route request is from 11213 to 11218 and 11213 is
> missing from the results and 11218 is duplicated. Does this indicate some
> weird off by one issue?
> It would be nice this this were fixed in the underlying code as it is hard
> to detect and repair after the route is complete.
> Thanks,
>  -Steve
> Anton Patrushev wrote:
>> Hi Steve,
>> This is known issue and it also might also happen with first edge.
>> It happens because we have two edges for both way streets. For
>> example, we start (or end) with the edge which is both way streets.
>> For Shooting* I need to create two edges for both directions with
>> unique ids (original id for one direction and original id + max id for
>> reverse direction).
>>   id
>>  id+max_id
>> So, from the function interface we always get original id for both
>> start and end. And it might happen that the particular id for one or
>> both of them is an id for the reverse direction, so it passes the edge
>> twice - forth and back.
>> When result is returned, function reduces all ids higher than max_id
>> to give you original ids. Thus instead of sequence, for example, id ->
>> id+max_id you have id -> id.
>> Probably it is worth to add a check to the core Shooting* function
>> which forms an output sequence (and I actually thought I did it
>> already). I need to check the source code.
>> Anton.
>> On Fri, May 8, 2009 at 12:07 AM, Stephen Woodbridge
>>> Any idea why shooting_star would return the last segment twice???
>>> -Steve
>>> routing=# SELECT gid, the_geom
>>> routing-#                     FROM shooting_star_sp_cd(
>>> routing(#                         'st',
>>> routing(#                         11213,
>>> routing(#                         11218,
>>> routing(#                         0.0724637681159,
>>> routing(#                         'cost_time',
>>> routing(#                         'rcost_time',
>>> routing(#                         false);
>>>  gid  |
>>>    the_geom
>>>  11212 |
>>> 0105000020E610000001000000010200000003000000A83BA88CC54B5140782922711A44414058048149C74B51403832B9011F444140B8ECA0B9CF4B5140D84BD5C734444140
>>>  33942 |
>>> 0105000020E610000001000000010200000002000000F82D2A95B54B514008144FD950444140B8ECA0B9CF4B5140D84BD5C734444140
>>>  11217 |
>>> 0105000020E610000001000000010200000002000000E06B2FD39E4B514090B0354869444140F82D2A95B54B514008144FD950444140
>>>  11218 |
>>> 0105000020E610000001000000010200000002000000E8004137864B514068B4ABB383444140E06B2FD39E4B514090B0354869444140
>>>  11218 |
>>> (5 rows)
>>> shooting_star_sp_cd() function is just a straight wrapper around your
>>> standard function.
>>> CREATE OR REPLACE FUNCTION shooting_star_sp_cd(
>>>    geom_table varchar, sourceid int4, targetid int4, delta float8,
>>>    cost_column varchar, rcost_column varchar, dir boolean)
>>>    RETURNS SETOF GEOMS AS
>>> DECLARE
>>>        path_result record;
>>>        geom geoms;
>>>    query text;
>>>    id integer;
>>> BEGIN
>>>    query := generic_sp_query('shortest_path_shooting_star', geom_table,
>>>        sourceid, targetid, delta, cost_column, rcost_column, dir);
>>>    FOR path_result IN EXECUTE query
>>>        LOOP
>>>                 geom.gid      := path_result.gid;
>>>                 geom.the_geom := path_result.the_geom;
>>>         geom.id       := id;
>>>                 RETURN NEXT geom;
>>>        END LOOP;
>>>        RETURN;
>>> END;
>>> LANGUAGE 'plpgsql' VOLATILE STRICT;
>>> Pgrouting-users mailing list
>>> Pgrouting-users at lists.postlbs.org
>>> http://lists.postlbs.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
