[pgrouting-users] assign_vertex_id missing
Anton Patrushev anton at orkney.co.jp
Tue Nov 3 03:16:20 EST 2009
Hi Flavio,
This tutorial is a little bit outdated. We moved this function to a
separate file - routing_topology.sql, so all you need is to run
something like
psql -U postgres -f /usr/share/postlbs/routing_topology.sql routing
Sorry for that,
Anton.
On Tue, Nov 3, 2009 at 5:02 PM, flavio rigolon <flavio.rigolon at gmail.com> wrote:
> Hi list,
>  this is my first post in this ml: sorry in advance for the newbye question.
> I'm running on Debian (Lenny) and following this instructions (
> http://pgrouting.postlbs.org/wiki/1.x/MakeDebPackage ) I installed the
> package "postgresql-8.3-pgrouting".
> Then I create a db with spatial extension (lwpostgis.sql and
> spatial_ref_sys.sql) and then with pgrouting extension (routing_core.sql and
> routing_core_wrappers.sql). All fine.
> After importing data (via shp2pgsql) I try to create topology with the
> "assign_vertex_id" function but I get this:
> "ERROR:  function assign_vertex_id(unknown, numeric, unknown, unknown) does
> not exist"
> Infact, browsing the database via pgadmin3, I cannot see this function.
> Is this function deprecated? Or the debian installer missing it? Is there
> another way to build the topology?
> Thanks in advance for any hints
> ciao
> flavio
> Linux, perche' no? Io uso debian.
> Pgrouting-users mailing list
> Pgrouting-users at lists.postlbs.org
> http://lists.postlbs.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
