[pgrouting-users] assign_vertex_id missing
flavio rigolon flavio.rigolon at gmail.com
Tue Nov 3 04:08:14 EST 2009
 perhaps I solved.
Lookink the source direcotry (taken from the SVN) I found
"routing_topology.sql".
So I copied it in /usr/share/postlbs/. Then I run
psql -U postgres -f /usr/share/postlbs/routing_topology.sql routing
and now I see the function "assign_vertex_id" in the dabase....then I
continue.
Thanks a lot to all
PS: why the routing_topology.sql were not put in /usr/share/postlbs/ like
the other .sql files? Is this a bug?
ciao
flavio
Linux, perche' no? Io uso debian.
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20091103/c3ef7056/attachment.html
More information about the Pgrouting-users mailing list
