[pgrouting-users] Dijkstra vs. A-Star
    Anton Patrushev
    anton.patrushev at gmail.com
    Tue Nov 24 04:48:53 EST 2009
> Hi, then for larger dataset i should use dijkstra . then for small data you
> would recommend a-star?
It is difficult to tell definitely, it depends more on road network
structure and its density.
> and is there a difference between the routes the algorithms calculated, i
> mean is it possible dijkstra creates a different shortest path than a* ?
> what was your intention implementing two or more algorithms?
Yes, theoretically it is possible, however with the heuristic function
we use in A* (Euclidean distance to target) it is hardly possible. Of
course you can change it or make its value stronger than cost, then
you can probably see the difference.
Anton.
More information about the Pgrouting-users
