[pgrouting-users] Adding bike routes to database
Yasir Shoaib yasirshoa at gmail.com
Thu Aug 12 04:59:12 EDT 2010
Hi Daniel,
Thanks for replying.
There is the issue of my current bike routes data not being aligned to the
exiting streets (some differences are present). Also, I am not sure how ways
can be assigned multiple class id's. The Ontario.osm which was downloaded
didn't have bike data imported into the pgrouting db, unless I missed
something. Ontario.osm was downloaded from:
http://downloads.mapzen.mapzen.cloudmade.com/north_america/canada/ontario
To get things started, I tried adding the routes and then running the search
with lower cost assigned to bike routes and higher to other road networks
but this didn't work as intended. Maybe this is the problem that you mention
about nodes snapping relating to the high tolerance.
Although, I am continuing to look into this, based on above do you have any
suggestions on getting things working?
Thanks,
Yasir
On 11 August 2010 15:34, Daniel Kastl <daniel.kastl at georepublic.de> wrote:
> Hi Yasir,
> I have some bike routes data that I would like to insert to the 'ways'
>> table in my pgrouting database.
>> For routing using the added routes, do I need to run assign_vertex_id
>> again?
> If you can ensure that you keep a valid topology you don't have to run it
> again. But probably it's easier to do so.
>> Also, there are existing streets where the bike routes would be added,
>> would this be any problem?
> You might have a problem if nodes get very close to existing ones. they
> might "snap" if you set your "tolerance" value too high.
> Also I'm not sure you want to create new roads beside existing ones.
> Probably you would like to try to match your bike routes with existing
> roads.
> Best regards,
> Daniel
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20100812/c49a8ae1/attachment.html
More information about the Pgrouting-users mailing list
