[pgrouting-users] Setting the tolerance argument in assign_vertex_id
Daniel Kastl daniel.kastl at georepublic.de
Fri Aug 27 22:42:16 EDT 2010
Hi Steve,
That's right.
If you have very large ID's, which is often the case when you take an
already existing source/target ID, it can slow down the query.
So it's a good idea to renumber your source/target nodes as you said.
Thank you for all the examples! I think we should link this thread with the
tips & tricks wiki page.
Daniel
> I think pgrouting would prefer to have the nodes mostly sequential because
> of the way it allocates memory. But I'm not sure on that, anyway here are
> two ways you could try doing it:
> 1. Try using it directly:
> update <edge_table> set source=fromnode, target=tonode;
> 2. Try renumbering the nodes in an extra table:
> create table node_renum ( id serial, oldnode integer, primary key id);
> insert into node_renum (oldnode) (
>  select distinct nid from (
>    select source as nid from <edge_table> union
>    select target as nid from <edge_table>
>  ) as foo
> create index oldnode_idx on node_renum using btree (oldnode);
> analyze node_renum;
> update <edge_table> as a set a.source=b.id from node_renum as b where
> a.fromnode=b.oldnode;
> update <edge_table> as a set a.target=b.id from node_renum as b where
> a.tonode=b.oldnode;
>  Thanks for your continued hand holding.
> No problem.
> Sounds like a fun project.
> -Steve
>  Dan
>> --- On Fri, 8/27/10, Stephen Woodbridge<woodbri at swoodbridge.com>
>> wrote:
>>  From: Stephen Woodbridge<woodbri at swoodbridge.com> Subject: Re:
>>> assign_vertex_id To: "Dan Putler"<putler at yahoo.com>, "pgRouting
>>> Users List"<pgrouting-users at lists.osgeo.org> Received: Friday,
>>> August 27, 2010, 1:56 PM Dan,
>>> In general the data is not represented as 2.5D, it is all 2D and
>>> there are relationship tables the tell you about zlevels.
>>> Navteq uses zlevels and DMTI used to call it ren (Relative
>>> Elevation Nodes).
>>> Also I noticed the DMTI rte (Roads) layer appears to have FromNode
>>> and ToNode already assigned to the road network. These are logical
>>> equivalents to source and target columns.
>>> Well I have this info in my  CanMap RouteLogistic v. 6.3 reference
>>> manual.
>>> -Steve
>>> On 8/27/2010 2:45 PM, Dan Putler wrote:
>>>> Hi Steve,
>>>> I'm getting the hang of the layer diagnostics. The
>>> data was
>>>> originally in a shapefile, and there is no z value in
>>> the attribute
>>>> table, so it doesn't appear to be a 2.5d file. It does
>>> have both
>>>> length and length adjusted for elevation fields, just
>>> no z. Your tips
>>>> on the diagnostics have been very helpful (translating
>>> what you did
>>>> with Mapserver into QGIS is pretty straight forward).
>>> Over 5% of the
>>>> edges have zero length, but these overwhelmingly occur
>>> on the loops
>>>> of cul-de-sacs. In addition, I'm not finding any
>>> mid-street dead
>>>> ends.
>>>> Overall, I'm successful in routing between 85% and 90%
>>> of my test
>>>> cases using the shooting * algorithm. Some of the
>>> failures I'm
>>>> finding are very surprising, I have a hunch as to why
>>> some of them
>>>> are occurring (based on a likely two bridge, literal
>>> "island
>>>> hopping", route it would likely select), but so far
>>> I'm not finding a
>>>> problem in the road network with respect to dead-ends
>>> or zero length
>>>> segments that would cause it. The island hoping route
>>> does involve
>>>> two fairly complex interchanges, could the lack of
>>> detailed elevation
>>>> information on the interchanges be the cause of the
>>> problem?
>>>> I'm going to look at a couple of things, one of them
>>> is to go back to
>>>> the original DMTI layer to make sure I didn't somehow
>>> screw-up the
>>>> data being too clever with ogr2ogr, the other is to
>>> see if I get a
>>>> solution using the Dijkstra algorithm.
>>>> Again, thanks a lot for all your help.
>>>> Dan
>>>> Subject: Re:
>>>> in
>>>> Cc: "pgRouting
>>>> list"<pgrouting-users at lists.osgeo.org>
>>>> Received: Friday, August 27,
>>>> 2010, 9:00 AM Dan,
>>>>> One more thing that you might want to consider is
>>>> if the DMTI data
>>>> has zlevels at intersections, the you might need
>>>> to mimic
>>>> assign_vertex_id() in the form of
>>>> assign_vertex_id_3d() where you
>>>> update your edge endpoints with a Z value in the
>>>> vertices_tmp table
>>>> and you set the Z value to zlevel*FACTOR where
>>>> FACTOR greater than
>>>> TOLERANCE
>>>>> So if you have intersection points like at an
>>>> overpass where the
>>>> under pass is A-B(0)-C and the overpass is
>>>> J-B(1)-K
>>>>> B has and location (x,y) and the zlevel for A-B
>>>> and B-C is 0 and
>>>> the for edges J-B and B-K the zlevel is 1, so
>>>> while these are at
>>>> the same x,y they do not intersect. In the
>>>> assign_vertex_id(),
>>>> these will get assigned the same node, but you
>>>> need to write
>>>> assign_vertex_id_3d() so they would get different
>>>> nodes assign
>>>> based on the zlevel separation.
>>>>> -Steve
>>>>> On 8/27/2010 11:31 AM, Stephen Woodbridge wrote:
>>>>>> I think DMTI data is pretty high quality data.
>>>>> I have
>>>> used it in the
>>>>>> past, granted not for routing but, I never
>>>>> noticed any
>>>> quality problems.
>>>>>> When I did some of the analysis on other data
>>>>> sets, I
>>>> created extra
>>>>>> columns on the edges table an did things like
>>>>> mark the
>>>> edges for all
>>>>>> that had the same source and target nodes and
>>>>> display
>>>> them in using
>>>>>> mapserver and openlayers and displayed the
>>>>> vertices_tmp table with
>>>>>> deadends as red dots and other nodes as green
>>>>> dots.
>>>>>> Then you can get a quick visualization of the
>>>>> data.
>>>> Mostly what you want
>>>>>> to look for is to see if deadends fall on
>>>>> connected
>>>> lines, this
>>>>>> indicates a problem. Look for segments with
>>>>> matching
>>>> source and target
>>>>>> numbers (color them so they stick out on the
>>>>> map.
>>>>>> If you set the tolerance wrong you will see
>>>>> lots of
>>>> errors like these.
>>>>>> I also then run pgRouting and overlay that on
>>>>> the maps
>>>> and can turn on
>>>>>> the reference layers for debugging weird
>>>>> routes.
>>>>>> Look at this:
>>>>>> http://gis.imaptools.com/routing/leaddog/?zoom=10&lat=33.86222&lon=35.51589&layers=B0TTTF&start=35.504139%2033.833331&stop=35.546364%2033.883493&method=STS
>>>>>> 〈=eng
>>>>>>  Open the layer switcher, zoom in and select "Just the
>>  Streets" and "Dead
>>>>>> Ends" and you can see what I mean. "Just the
>>>>> Streets"
>>>> labels the streets
>>>>>> with the gid of the edge table so you can go
>>>>> investigate a problem.
>>>>>> -Steve
>>>>>> On 8/27/2010 3:44 AM, Dan Putler wrote:
>>>>>>> Thanks a lot Steve, this looks really
>>>>>> helpful. I
>>>> can see that routing
>>>>>> involves much of the same "art" that
>>>>>> geocoding
>>>> does.
>>>>>>> Based on past experience, I'm not sure
>>>>>> that the
>>>> road network I am
>>>>>> working with is as clean as you and Daniel
>>>>>> appear
>>>> to assume. I'm
>>>>>> going to look at the dead-end and other
>>>>>> issues
>>>> tomorrow. I'm also
>>>>>> wondering if there is any potential
>>>>>> benefit of
>>>> reading the original
>>>>>> shapefile into GRASS which will attempt to
>>>>>> clean
>>>> it, dumping it back
>>>>>> into a shapefile from GRASS, and then
>>>>>> importing it
>>>> into PostGIS, or
>>>>>> does assign_vertex_id basically do the
>>>>>> same
>>>> cleaning that GRASS
>>>>>> does?
>>>>>>> Dan
>>>>>>> --- On Thu, 8/26/10, Stephen
>>>>>>> Subject: Re:
>>>>>>> tolerance
>>>> argument in
>>>> Cc: "pgRouting
>>>>>>> Received: Thursday, August
>>>>>> 26, 2010, 8:55 PM Dan,
>>>>>>>> I think that picking a number around
>>>>>>> 0.5 to 1
>>>> meter should be fine
>>>>>> for that data. In general it is
>>>>>>> unlikely that
>>>> you will have nodes
>>>>>> that are NOT connected but that close
>>>>>>> together.
>>>>>>>> You can also do some analysis of the
>>>>>>> results
>>>> like this, after you
>>>>>> run assign_vertex_id():
>>>>>>>> alter table vertices_tmp add column
>>>>>>> cnt int;
>>>> update vertices_tmp
>>>>>> set cnt = (select count(*) from
>>>>>>> "<edge_table>" where
>>>>>> vertices_tmp.id=target or
>>>>>>> vertices_tmp.id=source); select cnt as
>>>>>> connections, count(*) from
>>>>>>> vertices_tmp group
>>>> by cnt order by cnt;
>>>>>>>> This will analyze the connectedness of
>>>>>>> you
>>>> network.
>>>>>>>> connections 1 - dead ends 2 -
>>>>>>> segments
>>>> connected but only an
>>>>>> intersection if different names 3+ -
>>>>>>> intersections
>>>>>>>> If you run assign_vertex_id() with
>>>>>>> different
>>>> tolerance values and
>>>>>> then run this analysis as your
>>>>>>> tolerance gets
>>>> too big you will see
>>>>>> a shift of these numbers to the
>>>>>>> smaller end
>>>> which is bad.
>>>>>>>> Another important analysis you check
>>>>>>> is:
>>>>>>> "<edge_table>"
>>>> where target=source;
>>>>>>>> this count should be zero unless you
>>>>>>> have zero
>>>> length segments in
>>>>>> your data and you can check that
>>>>>>> with:
>>>>>>>> select gid, st_length(the_geom) from
>>>>>> target=source;
>>>>>>>> These are a good way to learn about
>>>>>>> your
>>>> data.
>>>>>>>> -Steve
>>>>>>>> On 8/26/2010 8:37 PM, Dan Putler
>>>>>>> wrote:
>>>>  Thanks Steve, but I do need a bit
>>>>>>>> of a
>>>> follow on I
>>>>>> think, and
>>>>>>>>> probably provide a bit more
>>>>>>>> explanation.
>>>>>>>>> I'm using a DMTI CanMap routing
>>>>>>>> layer for
>>>> BC that
>>>>>> started out in
>>>>>>>>> NAD83 geographic, which I
>>>>>>>> converted to
>>>> NAD83 UTM Zone
>>>>>> 10N via
>>>>>>>>> ogr2ogr, I also shrank it down
>>>>>>>> using a
>>>> "with"
>>>>>> statement in ogr2ogr to
>>>>>>>>> cover only part of the province.
>>>>>>>> After I
>>>> sent my
>>>>>> email, I did a bit
>>>>>>>>> more Google searching and based on
>>>>>>>> a
>>>> question in the
>>>>>> pgRouting forum,
>>>>>>>>> a user using NAVTEQ layers was
>>>>>>>> using a
>>>> tolerance that
>>>>>> worked out to
>>>>>>>>> between 1 and 1.5 meters. Based on
>>>>>>>> this, I
>>>> set the
>>>>>> tolerance to 2
>>>>>>>>> meters, it sounds like I should
>>>>>>>> set the
>>>> tolerance in
>>>>>> assign_vertex_id
>>>>>>>>> to be much smaller (say 0.15
>>>>>>>> meters, which
>>>> is just
>>>>>> over 5 inches).
>>>>>>>>> In general, is it better to err on
>>>>>>>> the
>>>> side of too
>>>>>> small or too large
>>>>>>>>> a tolerance, or is that a "it
>>>>>>>> depends"
>>>> question?
>>>>>>>>> Dan
>>>>>>>>> Subject: Re:
>>>>>>>>> tolerance argument
>>>>>> in
>>>>>> Cc: "pgRouting
>>>>>>>>> 26, 2010, 4:27 PM On 8/26/2010
>>>>>>>>> 2:51
>>>> PM, Dan Putler
>>>>>> wrote:
>>>>>>>>> Hi,
>>>>>>>>>>> I'm curious how to
>>>>>>>>>> determine the
>>>> value of the
>>>>>> second
>>>>>>>>> argument in the
>>>>>>>>>>> function
>>>>>>>>>> assign_vertex_id(). Most
>>>> of the
>>>>>> examples I
>>>>>>>>> can find look
>>>>>>>>>>> like:
>>>>>>>>>>>  assign_vertex_id('<edge
>>>> table>', 0.001,
>>>>>>  'the_geom', 'gid')
>>>>>>>>>>> Most of the examples are
>>>>>>>>>> based on
>>>> edge tables
>>>>>> that
>>>>>>>>> have SRIDs that
>>>>>>>>>>> correspond to either
>>>>>>>>>> WGS84
>>>> geographic or some
>>>>>> sort of
>>>>>>>>> US State Plane
>>>>>>>>>>> feet. I'm using data that
>>>>>>>>>> is using
>>>> a UTM
>>>>>> coordinate
>>>>>>>>> SRID, so the map
>>>>>>>>>>> units are in meters. My
>>>>>>>>>> question
>>>> is whether
>>>>>> the map
>>>>>>>>> units should
>>>>>>>>>>> influence the choice of
>>>>>>>>>> the second
>>>> argument to
>>>>>> the
>>>>>>>>> function (which I
>>>>>>>>>>> assume is a tolerance
>>>>>>>>>> between
>>>> edges), or
>>>>>> should I just
>>>>>>>>> keep with the
>>>>>>>>>>> value 0.001? Implicitly,
>>>>>>>>>> I'm
>>>> asking if the
>>>>>> parameter
>>>>>>>>> is in the map
>>>>>>>>>>> units of the SRID.
>>>>>>>>>> Dan,
>>>>>>>>>> Right units is important.
>>>>>>>>>> When I use data in WGS84 that
>>>>>>>>> has at
>>>> lease 6
>>>>>> decimal places then I
>>>>>>>>> use 0.000001 as the tolerance.
>>>>>>>>> What
>>>> this means if
>>>>>> that if the
>>>>>>>>> distance between two points
>>>>>>>>> are less
>>>> than or equal
>>>>>> 0.000001 units
>>>>>>>>> then they should be considered
>>>>>>>>> the
>>>> same point.
>>>>>> 0.000001 degrees ==
>>>>>>>>> ~5 inches if I did the math
>>>>>>>>> right.
>>>>>>>>>> I think there are two issues
>>>>>>>>> you need
>>>> to be aware
>>>>>> of:
>>>>>>>>>> 1) units 2) your data and
>>>>>>>>> what
>>>> precision it was
>>>>>> built at
>>>>>>>>>> HTH, -Steve
>>>>>>  _______________________________________________ Pgrouting-users
>>>> mailing list Pgrouting-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Pgrouting-users mailing list
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20100828/52f0a7ee/attachment-0001.html
More information about the Pgrouting-users mailing list
