[pgrouting-users] Shooting star problem
Espen Isaksen espen.isaksen at gmail.com
Mon Dec 20 05:23:56 EST 2010
On Mon, Dec 20, 2010 at 11:11 AM, Daniel Kastl <daniel at georepublic.de> wrote:
> Hi Espen,
> Your projection unit is "meter", I guess. So if you decrease your bounding
> box to 10, then, there are no other edges in your select than the two you
> want to get as a result.
Yes that is understandable. Just hoped it would not jump to a
different "shortest path" when I increased the bounding box :-)
> But thank you for trying this, because it shows, that your result passes one
> link twice. Could you find out, if the cost of passing edge 157333 twice
> would be higher than taking the "long" way?
The cost of 15733 is 104.8033 so passing twice would be 209.6066 and
the cost of going around is 229.675.
If I rearrange the query and do not use the wrapper function I get this result:
routing=# SELECT * FROM shortest_path_shooting_star('SELECT gid as id,
source, target, cost, reverse_cost,x1, y1,x2, y2, rule, to_cost FROM
elveg order by id',157333,157332,true,true);
 vertex_id | edge_id |       cost
    269628 |  157333 |         104.8033
    269630 |  159163 |          62.3978
    266068 |  155337 |          75.4899
    256213 |  155336 |          29.7317
    266065 |  158776 |          62.0563
    269628 |  157332 | 61.7253486704361
(6 rows)
Espen
> Then the search result would be correct, but of course trying to pass one
> edge twice wouldn't be OK.
> Thank you for reporting this!
> Daniel
> 2010/12/20 Espen Isaksen <espen.isaksen at gmail.com>
>> Hi!
>> I am running the following query:
>> SELECT gid
>> FROM shootingstar_sp('elveg',157332,157333,100, 'cost', true, true);
>> and I get:
>>  gid
>>  157332
>>  157333
>> (2 rows)
>> which seems correct. Now if i flip the direction with the this query:
>> SELECT gid
>> FROM shootingstar_sp('elveg',157333,157332,100, 'cost', true, true)
>> then I get:
>>  gid
>>  157333
>>  159163
>>  155337
>>  155336
>>  158776
>>  157332
>> (6 rows)
>> which is not correct. There should not be any extra costs on the edges:
>>  gid   |       cost       |   reverse_cost   | to_cost | rule
>>  157332 | 61.7253486704361 | 61.7253486704361 |         |
>>  157333 |         104.8033 |         104.8033 |         |
>> (2 rows)
>> >From my understanding I should get 2 rows in both queries. Am I
>> missing something here?
>> If I decrease the bounding box in the second query to 10, then I get
>> this result:
>>  gid
>>  157333
>>  157333
>>  157332
>> (3 rows)
>> I thought I should get the same result for a larger bounding box as
>> long as the shortest path(least cost) is within the smallest bounding
>> box?
>> Image of the road network can be seen here:
>> http://dl.dropbox.com/u/8829/road_network.png
>> Espen
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
More information about the Pgrouting-users mailing list
