[pgrouting-users] Shooting star problem
Espen Isaksen espen.isaksen at gmail.com
Tue Dec 21 03:32:15 EST 2010
Hi Daniel!
I tried using the shootingstar_sp_smart wrapper function, but there
seems to be some problems here as well. Running it on a network with
cost=reverse_cost=st_length(the_geom) is fine from 157333 to 157165.
However, once I bump the value of the cost on 157332 to 100000, then
the route avoids 157332 in both directions. And setting reverse_cost
makes no difference at all.
Is this the correct way to run the query:
SELECT gid
FROM shootingstar_sp_smart(
'elveg',
261728.74707,
6648944.62891,
261852.04834,
6649001.15576,
10000, 'cost', true, true);
   gid
 1255980
 1255977
  157166
  157167
  155335
  158776
 1255978
 1255981
(8 rows)
SELECT gid
'elveg',
261852.04834,
6649001.15576,
261728.74707,
6648944.62891,
   gid
 1255980
 1255976
  158776
  155335
  157167
  157166
 1255979
 1255981
(8 rows)
Espen
On Mon, Dec 20, 2010 at 2:39 PM, Daniel Kastl <daniel at georepublic.de> wrote:
> Hi Espen,
> Have you tried to route with more than two road links, lets say from 157332
> to 157334?
> If you try both directions there, does it take two different routes as well?
> The starting points/edges are somtimes the ones, where issues are likely to
> occur.
> Which version of pgRouting do you use?
> I mostly use this wrapper function, that usually worked well for me:
> https://github.com/pgRouting/pgrouting-contrib/blob/master/wrapper/routing_core_smart.sql
> It takes X/Y of start and end point as parameter, looks for the nearest edge
> and then splits it into two substrings and selects the right one.
> Maybe this wrapper cares better about special cases, because I haven't had a
> strange route with it.
> Daniel
> 2010/12/20 Espen Isaksen <espen.isaksen at gmail.com>
>> On Mon, Dec 20, 2010 at 11:11 AM, Daniel Kastl <daniel at georepublic.de>
>> wrote:
>> > Hi Espen,
>> > Your projection unit is "meter", I guess. So if you decrease your
>> > bounding
>> > box to 10, then, there are no other edges in your select than the two
>> > you
>> > want to get as a result.
>> Yes that is understandable. Just hoped it would not jump to a
>> different "shortest path" when I increased the bounding box :-)
>> > But thank you for trying this, because it shows, that your result passes
>> > one
>> > link twice. Could you find out, if the cost of passing edge 157333 twice
>> > would be higher than taking the "long" way?
>> The cost of 15733 is 104.8033 so passing twice would be 209.6066 and
>> the cost of going around is 229.675.
>> If I rearrange the query and do not use the wrapper function I get this
>> result:
>> routing=# SELECT * FROM shortest_path_shooting_star('SELECT gid as id,
>> source, target, cost, reverse_cost,x1, y1,x2, y2, rule, to_cost FROM
>> elveg order by id',157333,157332,true,true);
>>  vertex_id | edge_id |       cost
>>    269628 |  157333 |         104.8033
>>    269630 |  159163 |          62.3978
>>    266068 |  155337 |          75.4899
>>    256213 |  155336 |          29.7317
>>    266065 |  158776 |          62.0563
>>    269628 |  157332 | 61.7253486704361
>> (6 rows)
>> Espen
>> > Then the search result would be correct, but of course trying to pass
>> > one
>> > edge twice wouldn't be OK.
>> > Thank you for reporting this!
>> > Daniel
>> >> Hi!
>> >> I am running the following query:
>> >> SELECT gid
>> >> FROM shootingstar_sp('elveg',157332,157333,100, 'cost', true, true);
>> >> and I get:
>> >>  gid
>> >>  157332
>> >>  157333
>> >> (2 rows)
>> >> which seems correct. Now if i flip the direction with the this query:
>> >> SELECT gid
>> >> FROM shootingstar_sp('elveg',157333,157332,100, 'cost', true, true)
>> >> then I get:
>> >>  gid
>> >>  157333
>> >>  159163
>> >>  155337
>> >>  155336
>> >>  158776
>> >>  157332
>> >> (6 rows)
>> >> which is not correct. There should not be any extra costs on the edges:
>> >>  gid   |       cost       |   reverse_cost   | to_cost | rule
>> >>  157332 | 61.7253486704361 | 61.7253486704361 |         |
>> >>  157333 |         104.8033 |         104.8033 |         |
>> >> (2 rows)
>> >> >From my understanding I should get 2 rows in both queries. Am I
>> >> missing something here?
>> >> If I decrease the bounding box in the second query to 10, then I get
>> >> this result:
>> >>  gid
>> >>  157333
>> >>  157333
>> >>  157332
>> >> (3 rows)
>> >> I thought I should get the same result for a larger bounding box as
>> >> long as the shortest path(least cost) is within the smallest bounding
>> >> box?
>> >> Image of the road network can be seen here:
>> >> http://dl.dropbox.com/u/8829/road_network.png
>> >> Espen
>> >> _______________________________________________
>> >> Pgrouting-users mailing list
>> >> Pgrouting-users at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>> > Georepublic UG & Georepublic Japan
>> > eMail: daniel.kastl at georepublic.de
>> > Web: http://georepublic.de
More information about the Pgrouting-users mailing list
