[pgrouting-users] Oneway problem
Ralf Suhr Ralf.Suhr at itc-halle.de
Fri Oct 15 08:37:02 EDT 2010
If the edge in database have the same start- and endnode you need only update
the reverse_cost column.
In case the direction (start-, endnode) are in reversed order the update will
only on cost column.
Am Freitag 15 Oktober 2010 14:23:16 schrieben Sie:
> But I think I have understood this correctly then. That is why I did this:
> update elveg set cost=length+1000000 where oneway='FT' ;
> update elveg set reverse_cost=length+1000000 where oneway='TF'
> This should do exactly what you explained.
> However, I wonder if this should concern me?
> http://pgrouting.postlbs.org/ticket/212
> Espen
> On Fri, Oct 15, 2010 at 2:08 PM, Ralf Suhr <Ralf.Suhr at itc-halle.de> wrote:
> > Hi Espen,
> > one edge is defined by to nodes in pgrouting.
> > You need to match the definition of oneway street to the edge.
> > If the direction of edge and oneway street are the same, then only the
> > reverse_cost must be higher. In case direction from edge are opposite to
> > oneway street, the reverse_cost become the the cost for driving the
> > oneway street.
> > Gr
> > Ralf
> > Am Freitag 15 Oktober 2010 13:34:47 schrieb Espen Isaksen:
> >> Hi!
> >> I have a feeling there is something I do not understand concerning
> >> routing with oneway streets, but after hours of testing and googling I
> >> have to ask you guys on this list.
> >> I have a street network for Norway in my database and I have added the
> >> columns cost and reverse_cost. I have initially set both columns to
> >> the value of the length of the geometry.
> >> Then I updated cost and reverse cost by this:
> >> update elveg set reverse_cost=length+1000000 where oneway='TF' ;
> >> I have this sql running shooting star. The sql is from the FOSS4G
> >> workshop:
> >> SELECT rt.gid, ST_AsGeoJSON(rt.the_geom) AS geojson,
> >> length(rt.the_geom) AS length, elveg.gid
> >> FROM elveg,
> >> (SELECT gid, the_geom
> >> FROM shootingstar_sp(
> >>                         'elveg',
> >>                         157334,
> >>                         157165,
> >>                         10000, 'cost', true, true)
> >>                      ) as rt
> >> WHERE elveg.gid=rt.gid
> >> What happens is that if I set the cost column high, the route will not
> >> travel on this road in both directions. And whatever I set
> >> reverse_cost, there is no changes to the route.
> >> Do I need to explain pgrouting to use the reverse_cost column? And why
> >> is the cost column working both directions?
> >> Espen
> >> _______________________________________________
> >> Pgrouting-users mailing list
> >> Pgrouting-users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
