[pgrouting-users] Oneway problem
Espen Isaksen espen.isaksen at gmail.com
Mon Oct 18 09:50:29 EDT 2010
Ok, no problem. But that leaves the question still open of why it does
not work. Anyone have an idea?
Espen
On Mon, Oct 18, 2010 at 12:00 PM, Ralf Suhr <Ralf.Suhr at itc-halle.de> wrote:
> Hello Espen,
> my fault. I did not read FT != TF. Your sql updates are ok. Setting
> reverse_cost will not have any effect for calculating a forward route.
> Gr
> Ralf
> Am Montag 18 Oktober 2010 09:12:10 schrieb Espen Isaksen:
>> Ok, sorry for not being clear here(and my absence this weekend).
>> Oneway=FT means one way in the direction of the geometry, oneway=TF
>> means one way in the opposite direction of the geometry. A regular two
>> way road has a null value in the oneway column.
>> So I got three values in the oneway column, TF, FT and null.
>> For starters I set cost and reverse_cost equal to the length column as
>>  this:
>> update elveg set cost=length
>> update elveg set reverse_cost=length
>> Then I up the cost for oneway streets by setting the value of the cost
>> column higher where the one way street is the same direction as the
>> geometry and the reverse_column higher where the one way street is in
>> the opposite direction of the the geometry:
>> update elveg set cost=length+1000000 where oneway='FT' ;
>> update elveg set reverse_cost=length+1000000 where oneway='TF'
>> Sorry if I am completely misunderstanding this stuff, but I thought
>> this should be fairly easy.
>> Espen
>> On Fri, Oct 15, 2010 at 4:06 PM, Ricardo Bayley
>> <ricardo.bayley at gmail.com> wrote:
>> > Espen,
>> > I dont understand why you set both cost and reverse_cost to the same
>> > value ? Shouldn´t you be setting
>> > cost = length
>> > reverse_cost = length + 100000 ?
>> > (or the other way around depening on the one_way value)
>> > update elveg set cost= length where oneway='FT' ;
>> > update elveg set reverse_cost= length+1000000 where oneway='TF'
>> > Ricardo
>> > On Fri, Oct 15, 2010 at 10:54 AM, Espen Isaksen <espen.isaksen at gmail.com>
>> > wrote:
>> >> I'm sorry Ralf, I do not understand what you mean here. I'll give some
>> >> more description of the data to make it more clear from my side.
>> >> This is the edge being a one way street:
>> >>  gid   | target | source |  cost   | reverse_cost | oneway
>> >>  157332 | 714814 | 714597 | 1 | 1000062 | TF
>> >> >From my understanding I should be able to create a route in the
>> >> direction of the edge, but the reverse_cost should come into play when
>> >> I route the opposite direction? An thus make the route go around.
>> >> And the direction is the direction of the geometry right?
>> >> Espen
>> >> On Fri, Oct 15, 2010 at 2:37 PM, Ralf Suhr <Ralf.Suhr at itc-halle.de>
> wrote:
>> >> > If the edge in database have the same start- and endnode you need only
>> >> > update
>> >> > the reverse_cost column.
>> >> > In case the direction (start-, endnode) are in reversed order the
>> >> > update will
>> >> > only on cost column.
>> >> > Am Freitag 15 Oktober 2010 14:23:16 schrieben Sie:
>> >> >> But I think I have understood this correctly then. That is why I did
>> >> >> this:
>> >> >> This should do exactly what you explained.
>> >> >> However, I wonder if this should concern me?
>> >> >> http://pgrouting.postlbs.org/ticket/212
>> >> >> Espen
>> >> >> On Fri, Oct 15, 2010 at 2:08 PM, Ralf Suhr <Ralf.Suhr at itc-halle.de>
>> >> >> wrote:
>> >> >> > Hi Espen,
>> >> >> > one edge is defined by to nodes in pgrouting.
>> >> >> > You need to match the definition of oneway street to the edge.
>> >> >> > If the direction of edge and oneway street are the same, then only
>> >> >> > the
>> >> >> > reverse_cost must be higher. In case direction from edge are
>> >> >> > opposite to
>> >> >> > oneway street, the reverse_cost become the the cost for driving the
>> >> >> > oneway street.
>> >> >> > Gr
>> >> >> > Ralf
>> >> >> > Am Freitag 15 Oktober 2010 13:34:47 schrieb Espen Isaksen:
>> >> >> >> Hi!
>> >> >> >> I have a feeling there is something I do not understand concerning
>> >> >> >> routing with oneway streets, but after hours of testing and
>> >> >> >> googling I
>> >> >> >> have to ask you guys on this list.
>> >> >> >> I have a street network for Norway in my database and I have added
>> >> >> >> the
>> >> >> >> columns cost and reverse_cost. I have initially set both columns
>> >> >> >> to the value of the length of the geometry.
>> >> >> >> Then I updated cost and reverse cost by this:
>> >> >> >> update elveg set reverse_cost=length+1000000 where oneway='TF' ;
>> >> >> >> I have this sql running shooting star. The sql is from the FOSS4G
>> >> >> >> workshop:
>> >> >> >> SELECT rt.gid, ST_AsGeoJSON(rt.the_geom) AS geojson,
>> >> >> >> length(rt.the_geom) AS length, elveg.gid
>> >> >> >> FROM elveg,
>> >> >> >> (SELECT gid, the_geom
>> >> >> >> FROM shootingstar_sp(
>> >> >> >>                         'elveg',
>> >> >> >>                         157334,
>> >> >> >>                         157165,
>> >> >> >>                         10000, 'cost', true, true)
>> >> >> >>                      ) as rt
>> >> >> >> WHERE elveg.gid=rt.gid
>> >> >> >> What happens is that if I set the cost column high, the route will
>> >> >> >> not
>> >> >> >> travel on this road in both directions. And whatever I set
>> >> >> >> reverse_cost, there is no changes to the route.
>> >> >> >> Do I need to explain pgrouting to use the reverse_cost column? And
>> >> >> >> why
>> >> >> >> is the cost column working both directions?
>> >> >> >> Espen
>> >> >> >> _______________________________________________
>> >> >> >> Pgrouting-users mailing list
>> >> >> >> Pgrouting-users at lists.osgeo.org
>> >> >> >> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
