R: Re: [pgrouting-users] assign_vertex_id trouble
zeusxxl at virgilio.it zeusxxl at virgilio.it
Thu Feb 3 08:51:19 EST 2011
Ok, it's this:
# SELECT assign_vertex_id('office',0.0001,'geom','id');
NOTICE:  CREATE TABLE will create implicit sequence "vertices_tmp_id_seq" for serial column "vertices_tmp.id"CONTEXT:  SQL statement "CREATE TABLE vertices_tmp (id serial)"PL/pgSQL function "assign_vertex_id" line 14 at EXECUTE statementERROR:  query string argument of EXECUTE is nullCONTEXT:  PL/pgSQL function "assign_vertex_id" line 35 at EXECUTE statement
----office is a table (id int4,name varchar(20),geom geometry)----
thanks for the answer!
----Messaggio originale----
Da: daniel at georepublic.de
Data: 3-feb-2011 10.37 AM
A: "pgRouting users mailing list"<pgrouting-users at lists.osgeo.org>
Ogg: Re: [pgrouting-users] assign_vertex_id trouble
Can you post your query?
Daniel
2011/2/3 Andrea Mazzeschi <zeusxxl at virgilio.it>
Hi I'm andrea. I'm new in pgrouting, postgis and similar. I was following this useful guide http://goo.gl/FuIiF to create a network topology. However when I try to execute the command
assign_vertex_id('<table>', float tolerance, '<geometry column', '<gid>')to my table, I have this response:
Do anyone know what's the problem?(sorry for my bad english)
_____________________
zEuSsEe.mail: zeusxxl at virgilio.it
Pgrouting-users mailing list
Pgrouting-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG &amp; Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110203/4f0ac919/attachment-0001.html
More information about the Pgrouting-users mailing list
