[pgrouting-users] Problem with shortest_path_shooting_star and reverse_cost
Adil BOUMAZOUED boumazoued at gmail.com
Mon Feb 7 09:11:08 EST 2011
I have a problem with shortest_path_shooting_star and shootingstar_sp
I use pgRouting-1.03_pg-8.3.7 with postgresql-8.3.10-1-windows and
postgis-pg83-setup-1.3.3-1
For Data, i use a personal data.
I create my graph and I add "temps" as "cost" and "reverse_temps" as
"reverse_cost" and I set reverse_temps=1000000 when direction=1.
When I run shortest_path_shooting_star :
$sql = "SELECT roads.edge_id0, AsText(roads.the_geom) AS wkt, roads.length,
roads.gid
            FROM roads, (SELECT edge_id FROM
shortest_path_shooting_star('SELECT gid as id, source, target,temps as
cost,reverse_temps as reverse_cost, x1, y1, x2, y2, rule, to_cost FROM roads
order by id',
            ".$startEdge['gid'].",
            ".$endEdge['gid'].",
              true, true)) as rt
              WHERE ".TABLE.".gid=rt.edge_id;";
Pgrouting return a bad calcul (it not considerate reverse_cost : figure 1)
Value 0 : both trajet
Value 1 : one direction (drawing direction)
 When I use shootingstar_sp :
$sql = "SELECT rt.gid, AsText(rt.the_geom) AS wkt,
                     length(rt.the_geom) AS length, ".TABLE.".id
                  FROM ".TABLE.",
                      (SELECT gid, the_geom
                          FROM shootingstar_sp(
                              '".TABLE."',
                              1, 'temps',true,true)
                       ) as rt
                  WHERE ".TABLE.".gid=rt.gid;";
I have a similar result (figure 1).
But when I use :
                  FROM ".TABLE.",
                              '".TABLE."',
                              1, 'temps',true,false)
                       ) as rt
I have a correct result (figure 2), but my graph will not be oriented and I
whill have bad calcul when I navigate between roads who have both direction
(figure 3 is correct but figure4 is not correct).
Thanks
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110207/4cf56667/attachment.html
More information about the Pgrouting-users mailing list
