[pgrouting-users] Cannot Create a Network Nodes network nodes
Daniel Kastl daniel at georepublic.de
Wed Feb 16 03:04:09 EST 2011
2011/2/16 Piyush Shah <piyush_shah at ymail.com>
> Thank You for your Reply,
> But I know What is the problem when i had see the assign_vertex_idfunction in that there is one for loop for taking srid
> value from input geom_table at that point only Error is occurring so i had
> statically assign the srid := 4326 (my Spatial table projection) the
> function works perfectly.
> But you can help to understand what is the problem in that "for loop"
> I am sending the function body to you in that i had highlighted the code
> where error is occurring (See Below) :-
You network data table has probably no correct entry in the
"geometry_columns" table or the SRID of the geometry is not set correctly
(-1?).
In general it's a good idea to have this set correctly. But this is not a
pgRouting specific problem.
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110216/a8239183/attachment.html
More information about the Pgrouting-users mailing list
