[pgrouting-users] dijkstra_sp_delta throwing a signal 6 (SIGABRT?)
Richard Marsden winwaed at gmail.com
Mon Feb 28 14:49:45 EST 2011
Well I've moved forward and now have code in production calculating mileages
from OpenStreetMap data: I've calculated mileage charts for Oceania and
Africa.
The secret to get that far was to move operating systems from Windows to
Ubuntu and then upgrade to pgRouting 1.05. (PostGres 8.4, Ubuntu 10)
Th computations are being performed with dijkstra_sp_delta.
However now I'm hitting another "server closed the connection unexpectedly"
error.
Looking in the server logs, I find the LOG message "server process (PID
19133) was terminated by signal 6: Aborted"
>From what I can tell, Signal 6 on Ubuntu is indeed a SIGABRT. There are no
other log messages to indicate why Postgres/pgRouting threw a SIGABRT.
This is then followed by warnings and log messages saying other active
server processes are being terminated, transactions rolled back, etc.
This error occurs at a reproducible point in a fairly sophisticated
(multi-processor, Python, psycopg) script. Although I'm pretty certain of
the SQL that is causing the problem, at the moment I don't have the exact
parameters (ie. graph nodes). I'm about to run the script single-threaded
with diagnostics so I should be able to get a single SQL statement to
reproduce the problem on a psql command line. In the worst case, this could
take a couple of days.
No other programs are running that are calling Postgres.
My graph consists of the global OSM street data loaded into PostGIS with
osm2po. I have checked for links of zero length. In fact all links <1m long
have been taken out of the graph. I've just double checked costs and
reverse_costs:  all are positive (I've set these to the lengths)
I've just checked for start & end nodes being the same (ie. resulting in
dijkstra_sp_delta being called with the some node identifier for the start
and end): Yes my data has a few of these, but I'm pretty certain the crash
occurs before they appear. However, I'm going to add code to detect these -
there's no point in executing an SQL statement for something that can be
calculated in a trivial line of python.
What else should I be looking for? Are there any known problems I should
look for? Is there any way of finding out what is causing the Signal 6?
Once I have the node identifiers that are causing the problem, I should be
able to make en exportable-extract of the graph to give a reproducible
dataset and matching SQL statement. Would anyone be able to investigate
this?
Is there any way of making pgRouting / PostGres handle these situations more
cleanly? At the moment, the crash is taking the server down with it. The
crash is perhaps the first to occur after roughly 1 million route
calculations: I can live with that failure rate - but only if my scripts can
cleanly detect and recover from it. I guess ideally the server should stay
up and a status value (or exception - but that probably wouldn't work across
so many code boundaries) be returned.
Best regards,
Richard Marsden
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110228/9869ff87/attachment.html
More information about the Pgrouting-users mailing list
