[pgrouting-users] Question about driving_distance calculation
Markus Innerebner markus.innerebner at inf.unibz.it
Tue Jan 11 11:34:11 EST 2011
Hello Daniel
thanks for your detailed answers.
> Driving Distance functions starts with a vertex. (There is a wrapper
> function that takes coordinates as start and searches for the nearest vertex
> from the given point).
>> 2) what happens with edges, that are partially reached? (one vertex is
>> reached in time, the other one is not)
> Driving Distance only cares about vertices, because it works like Dijkstra
> algorithm. You can take the vertices and write an SQL function for example,
> that returns you the edges ... or a polygon.
ok, thanks
The algorithm uses only the cost column(or reverse_cost column) of the
edges to compute the costs of the target vertex? This means there is no
way to compute the cost in dependency of a passed walking speed
parameter, where cost are defined as edge_length/speed.
regards
Markus
More information about the Pgrouting-users mailing list
