[pgrouting-users] Import large OSM data for routing
lorenzo amato lorenzo.amato at geosdi.org
Thu Jan 20 02:55:49 EST 2011
Hi Daniel,
thanks for the quick replay..
.. but the output is the same.
osm2po=# SELECT id, gid, AsText(the_geom) from
astar_sp_delta('osm_topo',723,6610,0.1);
LOG:  statement: SELECT id, gid, AsText(the_geom) from
 id | gid  |
 astext
  1 |  682 | MULTILINESTRING((14.9979217 41.9939472,14.997744 41.9942112))
  2 |  683 | MULTILINESTRING((14.997744 41.9942112,14.9974089
41.9947092,14.9962375 41.9963223,14.9958494 41.9966941))
  3 |  685 | MULTILINESTRING((14.9982187 41.9934783,14.9982846 41.9933772))
  4 |  686 | MULTILINESTRING((14.9982846 41.9933772,14.9983547
41.9932913,14.9983794 41.9932546,14.9984662 41.9931742,14.99858 41.993024))
  5 |  693 | MULTILINESTRING((14.9980506 41.9937596,14.9981486
41.9935518,14.9982187 41.9934783))
  6 |  696 | MULTILINESTRING((14.9979217 41.9939472,14.9979489 41.9939108))
  7 |  697 | MULTILINESTRING((14.9979489 41.9939108,14.9980265
41.9938069,14.9980506 41.9937596))
  8 | 7818 | MULTILINESTRING((14.9998359 41.9912293,14.9997606 41.991339))
  9 | 7819 | MULTILINESTRING((14.9997606 41.991339,14.9991878
41.9921736,14.9987675 41.9927617))
 10 | 7820 | MULTILINESTRING((14.9987675 41.9927617,14.99858 41.993024))
(10 rows)
astar_sp_delta('osm_topo',723,6610,0.1) ORDER BY id;
 id | gid  |
 astext
(10 rows)
2011/1/19 Daniel Kastl <daniel at georepublic.de>
> Hi Lorenzo,
> Can you try to also output "id" with "ORDER BY id"
> This "id" should be in the right order ... but I'm not 100% sure this was
> added to all wrapper functions. Can you try once?
> Daniel
> 2011/1/20 lorenzo amato <lorenzo.amato at geosdi.org>
> Hi List
>> before import the whole italy.osm with osm2po I'm doing some test with a
>> smaller portion of data.
>> I notice a strange behaviour:
>> If I use the core A* function I get a correct resultset (i.e.
>> multininestrings are consecutive)
>> If I use the wrapper function astar_sp_delta I get a wrong resultset (i.e.
>> multilinestring ordered by gid and not consecutive)
>> This not affects the rendering of the whole route, but makes impossible
>> other operations like the driving direction calculation, tha needs to
>> compare two consecutive rows of the result at time.
>> *Any idea on why this appen?*
>> This is an example to understand the different results:
>> osm2po=# SELECT * from shortest_path_astar('select gid as id, source,
>> target, length as cost, x1,y1,x2,y2 from osm_topo',723,6610,false,false);
>> LOG:  statement: SELECT * from shortest_path_astar('select gid as id,
>> source, target, length as cost, x1,y1,x2,y2 from
>>  vertex_id | edge_id |   cost
>>        723 |     683 | 0.006361
>>        722 |     682 | 0.000656
>>        721 |     696 |  9.3e-05
>>        732 |     697 | 0.000377
>>        731 |     693 | 0.000575
>>        726 |     685 |  0.00025
>>        727 |     686 | 0.000927
>>        724 |    7820 | 0.000661
>>       2333 |    7819 | 0.003565
>>        976 |    7818 | 0.000274
>>       6610 |      -1 |        0
>> (11 rows)
>> osm2po=# SELECT gid, AsText(the_geom) from
>> LOG:  statement: SELECT gid, AsText(the_geom) from
>>  gid  |                                                            astext
>> (10 rows)
>> 2011/1/19 lorenzo amato <lorenzo.amato at geosdi.org>
>> Richard
>>> Thanks very much for your suggestion.
>>> I'mk going to test osm2po for creating pgRouting compatible tables and it
>>> seems great.
>>> I will post to the list some more considerations at the end of my tests.
>>> Lorenzo
>>> 2011/1/18 Richard Marsden <winwaed at gmail.com>
>>> Try the osm2po program instead. This can handle large files, and recently
>>>> I was able to use it to import planet.osm. Osm2po create an SQL script which
>>>> you then execute. Planet.osm took a few days to import - Italy should be a
>>>> lot quicker!
>>>> Search the archives of this list server - I had a couple of queries
>>>> which were quickly answered. They may help you, especially if you are new to
>>>> PostGis and pgRouting (as I am).
>>>> Richard.
>>>> On Jan 18, 2011, at 10:42 AM, lorenzo amato <lorenzo.amato at geosdi.org>
>>>> wrote:
>>>> Hi list
>>>> I'm trying to import a large osm file (italy.osm from cloudmade) into
>>>> postgis using the osm2pgrouting tool without success.
>>>> I read somewhere in the list (or in the wikies) that osm2pgrouting uses
>>>> a large amount of memory.
>>>> So i tried to lounch osm2pgrouting on a workstation with 32G RAM ...
>>>> without success.
>>>> I also found this thread:
>>>> <http://download.osgeo.org/pgrouting/forum/pgrouting.postlbs.org/discussion/topic/297.html>
>>>> and this wiki page
>>>> <http://download.osgeo.org/pgrouting/forum/pgrouting.postlbs.org/wiki/osm2pgroutingPatchToAppendFile.html>
>>>> but some errors occurred whan I tryed to apply the patch.
>>>> Any help?
>>>> Or any other way to import large OSM data for routing?
>>>> Lorenzo Amato
>>>> <lorenzo.amato at geosdi.org>lorenzo.amato at geosdi.org
>>>> <lorenzotlc at gmail.com>lorenzotlc at gmail.com
>>>>  <lorenzo.amato at nsdi.it>lorenzo.amato at nsdi.it
>>>> Consiglio Nazionale delle Ricerche
>>>> Istituto di Metodologie per l'Analisi Ambientale - geoSDI
>>>> _______________________________________________
>>>> Pgrouting-users mailing list
>>>> Pgrouting-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>>> Lorenzo Amato
>> Lorenzo Amato
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
Lorenzo Amato
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110120/32b3f175/attachment-0001.html
More information about the Pgrouting-users mailing list
