[pgrouting-users] about use of navteq data
lorenzo amato lorenzo.amato at geosdi.org
Mon Jan 24 11:36:45 EST 2011
Hi Charles, Hi list
I'm approaching Navteq data in this days.
I have a navteq shapefile streets.shp, so the first thing to do (i suppose)
is to import it in postgis with the shp2postgresql tool or with ogr2ogr
library.
After that, with this:
2011/1/24 Charles Galpin <cgalpin at lhsw.com>
> .. but in theory you should be able to use navteq's ref_in_id and
> nref_in_id  which are the equivalent of the source/target pgRouting builds
> itself, but I had issues (but can't recall the specifics).
you mean that I can directly use pgrouting on navteq data using ref_in_id
and nref_in_id as source and target?
Thanks to all
Lorenzo Amato
lorenzotlc at gmail.com
lorenzo.amato at nsdi.it
Consiglio Nazionale delle Ricerche
Istituto di Metodologie per l'Analisi Ambientale - geoSDI
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110124/c5167a0b/attachment.html
More information about the Pgrouting-users mailing list
