[pgrouting-users] Error whilst installing on CentOS 5.5
Richard Willars richard.willars at lemonstorm.com
Mon Jan 24 12:07:01 EST 2011
Hi Charles,
Thanks for the advice. Unfortunately I've already got boost-devel
installed (v1.33.1). I can see there's a newer version of boost
available (1.45) but it's not available via yum.. if I can work out
how to install it I will, but before I spend ages on that do you think
that that minor update would fix the issue?
Regards,
Richard
On Mon, Jan 24, 2011 at 4:21 PM, Charles Galpin <cgalpin at lhsw.com> wrote:
> Hi Richard
> You need the boost-devel rpm.
> hth
> charles
> On Jan 24, 2011, at 11:13 AM, Richard Willars wrote:
>> Hi all,
>> I'm trying to install the pgrouting library but have hit a bit of a
>> problem whilst installing. It's probably something I've done (I'm
>> quite new to Linux so struggling to understand the error message). I
>> followed the instructions given at
>> http://www.pgrouting.org/docs/1.x/install_centos.html and I'm
>> installing on CentOS 5.5. Has anyone seen this before or have any
>> ideas how to resolve it?
>> [root at localhost pgrouting]# git clone
>> git://github.com/pgRouting/pgrouting.git pgrouting
>> [root at localhost pgrouting]# cd pgrouting
>> [root at localhost pgrouting]# sudo /root/cmake-2.8.3-Linux-i386/bin/cmake .
>> [root at localhost pgrouting]# make install
>> [ 16%] Building CXX object
>> core/src/CMakeFiles/routing.dir/shooting_star_boost_wrapper.o
>> /root/pgrouting/core/src/shooting_star_boost_wrapper.cpp:26:54: error:
>> boost/property_map/vector_property_map.hpp: No such file or directory
>> In file included from
>> /root/pgrouting/core/src/shooting_star_search.hpp:22, from
>> /root/pgrouting/core/src/shooting_star_boost_wrapper.cpp:27:
>> /root/pgrouting/core/src/shooting_star_relax.hpp:18:47: error:
>> boost/property_map/property_map.hpp: No such file or directory
>> make[2]: [core/src/CMakeFiles/routing.dir/shooting_star_boost_wrapper.o]
>> Error 1 make[1]:[core/src/CMakeFiles/routing.dir/all] Error 2 make:
>> [all] Error 2
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
