[pgrouting-users] Error whilst installing on CentOS 5.5
Charles Galpin cgalpin at lhsw.com
Mon Jan 24 12:19:36 EST 2011
I don't think the version os the problem since I am running the same. I don't recall what I did exactly but did run ldconfig at some point.  Perhaps run that and try again.
However I have since learned about pgrpms and in theory installing postgis should be as simple as
rpm -ivh http://yum.pgrpms.org/reporpms/9.0/pgdg-centos-9.0-2.noarch.rpm
yum install postgis90
This ets the postgres repos setup and then installs postgis and all dependencies from it.
There is a remote chance you'd need to edit /etc/yum.repos.d/CentOS-Base.repo [base] and [updates] sections and add
exclude=postgresql*
This might be worth a try (I have tried this in a fresh VM and it appears to have worked fine but have not attempted to use it yet). Long term this is a much better approach than building from scratch each time (for me). I am not sure if this includes pgrouting, but it's a good start even if not.
hth
charles
On Jan 24, 2011, at 12:07 PM, Richard Willars wrote:
> Hi Charles,
> Thanks for the advice. Unfortunately I've already got boost-devel
> installed (v1.33.1). I can see there's a newer version of boost
> available (1.45) but it's not available via yum.. if I can work out
> how to install it I will, but before I spend ages on that do you think
> that that minor update would fix the issue?
> Regards,
> Richard
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110124/7f6dfda1/attachment.html
More information about the Pgrouting-users mailing list
