[pgrouting-users] Table location
Dan Putler putler at yahoo.com
Fri Jan 28 01:39:35 EST 2011
Given your comment on vertex assignments needing to be done in the public schema, I'm now not sure. I may have had a problem with the vertex assignments, looked through that code and discovered that it didn't handle anything other than the public schema well, and just put everything in public after that. I did this in July, so things are on the hazy side. What I was working on isn't part of a web application, and I am behind a firewall, so I was safe in keeping everything in the public schema.
Dan
--- On Thu, 1/27/11, Henrik Berggren <henke.berggren at gmail.com> wrote:
From: Henrik Berggren <henke.berggren at gmail.com>
Subject: Re: [pgrouting-users] Table location
To: "pgRouting users mailing list" <pgrouting-users at lists.osgeo.org>
Received: Thursday, January 27, 2011, 10:26 AM
  Are you sure about that the data needs to be in the public schema
    for shooting_star to work properly?
    /Henrik
    On 01/27/2011 07:06 PM, Dan Putler wrote:
            I also found that I
              could only use pgrouting with a data table that are in the
              public schema. My memory is that in some of the functions
              (I know this is true for the shooting star algorithm), the
              public schema is "hard wired" within the code.
              Dan
              --- On Thu, 1/27/11, Daniel Kastl <daniel at georepublic.de>
                Received: Thursday, January 27, 2011, 8:18 AM
                Good question, Ricardo!
                  And thank you for sharing your experience,
                    Henrik.
                  I must admit I haven't tried it, and probably the
                    majority of users always works in public schema.
                  I added a ticket not to forget about this,
                    because I think it would be nice to support
                    the schema in all functions:
                  https://github.com/pgRouting/pgrouting/issues/issue/24
                    Daniel
                    2011/1/28
                         You can have it in other schemes but you
                          need to run the assign_vertex_id in the public
                          scheme, that is my experience.
                          /H
                              On 01/25/2011 10:42 PM, Ricardo Bayley
                              wrote:
                              Hi everyone,
                                I am wondering, does pgrouting
                                  require to have tables on the public
                                  schema ? or could they be on any
                                  schema ?
                                Thanks,
                                Ricardo
Pgrouting-users mailing list
Pgrouting-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
                    Georepublic
                      UG & Georepublic Japan
                      eMail: daniel.kastl at georepublic.de
                      Web: http://georepublic.de
                -----Inline Attachment Follows-----
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110127/0e84ecfb/attachment.html
More information about the Pgrouting-users mailing list
