[pgrouting-users] Table location
Daniel Kastl daniel at georepublic.de
Sat Jan 29 22:33:37 EST 2011
2011/1/30 Stephen Woodbridge <woodbri at swoodbridge.com>
> On 1/29/2011 12:36 PM, Dan Putler wrote:
>> Hi Steve,
>> Have you submitted a patch with the changes? It seems like a good change.
> Nope, I never got around to patches, but after looking into the problem
> again, I may have been mistaken. The only place that 'public' is explicity
> used is in "core/sql/routing_topology.sql" in:
> _srid := Find_SRID('public','vertices_tmp','the_geom');
> And this should be ok, unless you move the location of 'vertices_tmp' to
> another schema.
Yes, I thought about this as well. I think, this hasn't changed since it
pgRouting was named pgDijkstra long time ago.
Without going through the code I would assume that wrapper functions like
shooting_star_smart might be affected as well.
But wrappers were seen more as examples how to write your own functions in
the beginning, so they were supposed to be modified by users as you are
doing.
> I have rewritten a lot of the wrapper code for my own purposes and it might
> not be general purpose anymore.
As I already said before. Though it seems having samples available for
others to learn from is a huge help.
> As some point when I have some spare time I will review my code changes and
> propose a set a patches back to the source tree. One of the other big
> changes I made for my purposes, was to rationalize the the wrapper API calls
> so that they are nearly identical except for the name. This makes if much
> easier to write generic code from an application point of view there you
> only need to change the function name to change the analysis getting done.
> Otherwise you have to basically code multiple paths to setup for the
> different functions as they now stand.
This is something I would like to discuss in the near future.
I think we could try to make function names a bit more consistent as they
are now.
Having some conventions or a naming schema here would make it easier.
Good proposals are welcome!
> Part of the motivation for this was writing the driving directions code so
> it had mimimal impact on the code when changing the analysis method between
> dijkstra, astar and shootingstar.
Right. I even thought about passing the algorithm name as the first
parameter for example and have then one function called shortest_path for
example.
Daniel
> -Steve
>  Dan
>> --- On Fri, 1/28/11, Stephen Woodbridge<woodbri at swoodbridge.com>  wrote:
>>  From: Stephen Woodbridge<woodbri at swoodbridge.com>
>>> Subject: Re: [pgrouting-users] Table location
>>> To: pgrouting-users at lists.osgeo.org
>>> Received: Friday, January 28, 2011, 10:00 AM
>>> I cloned vertex assignment code to
>>> change it for zlevels and it was
>>> trivial to make it run in another schema. I think all you
>>> need to do is:
>>> 1. remove all the explicit references to "public." from the
>>> stored
>>> procedure and reload it in you "data." schema
>>> 2. then make sure you set the default db search path like:
>>> alter database mydb set search_path to data, public;
>>> And everything is good.
>>> -Steve
>>> On 1/28/2011 1:39 AM, Dan Putler wrote:
>>>> Given your comment on vertex assignments needing to be
>>> done in the
>>>> public schema, I'm now not sure. I may have had a
>>> problem with the
>>>> vertex assignments, looked through that code and
>>> discovered that it
>>>> didn't handle anything other than the public schema
>>> well, and just put
>>>> everything in public after that. I did this in July,
>>> so things are on
>>>> the hazy side. What I was working on isn't part of a
>>> web application,
>>>> and I am behind a firewall, so I was safe in keeping
>>> everything in the
>>>> public schema.
>>>> Dan
>>>> --- On *Thu, 1/27/11, Henrik Berggren /<henke.berggren at gmail.com>/*
>>> wrote:
>>>>      From: Henrik Berggren<henke.berggren at gmail.com>
>>> Table location
>>>>      To: "pgRouting users mailing
>>> list"<pgrouting-users at lists.osgeo.org>
>>>>      Received: Thursday, January
>>> 27, 2011, 10:26 AM
>>>>      Are you sure about that the
>>> data needs to be in the public schema
>>>>      for shooting_star to work
>>> properly?
>>>>      /Henrik
>>>>      On 01/27/2011 07:06 PM, Dan
>>> Putler wrote:
>>>>      I also found that I could
>>>> only use pgrouting with a data table
>>>>      that are in the public
>>>> schema. My memory is that in some of the
>>>>      functions (I know this is
>>>> true for the shooting star algorithm),
>>>>      the public schema is "hard
>>>> wired" within the code.
>>>>>      Dan
>>>> Daniel Kastl /<daniel at georepublic.de>
>>>>      </mc/compose?to=daniel at georepublic.de>/*
>>>> wrote:
>>>>>          From: Daniel
>>>> Kastl<daniel at georepublic.de>
>>>>          Subject: Re:
>>>>          To:
>>>> "pgRouting users mailing list"
>>>>>     </mc/compose?to=pgrouting-users at lists.osgeo.org>
>>>>          Received:
>>>> Thursday, January 27, 2011, 8:18 AM
>>>>>          Good
>>>> question, Ricardo!
>>>>          And thank
>>>> you for sharing your experience, Henrik.
>>>>>          I must admit
>>>> I haven't tried it, and probably the majority of
>>>>          users always
>>>> works in public schema.
>>>>          I added a
>>>> ticket not to forget about this, because I think it
>>>>          would be
>>>> nice to support the schema in all functions:
>>>>          https://github.com/pgRouting/pgrouting/issues/issue/24
>>>>>          Daniel
>>>>>          2011/1/28
>>>>>     You can have it in other schemes but you
>>> need to run the
>>>>>     assign_vertex_id in the public scheme,
>>> that is my experience.
>>>>>     /H
>>>>>     On 01/25/2011 10:42 PM, Ricardo Bayley
>>> wrote:
>>>>>>     Hi everyone,
>>>>>>     I am wondering, does pgrouting require to
>>> have tables on
>>>>>>     the public schema ? or could they be on
>>> any schema ?
>>>>>>     Thanks,
>>>>>>     Ricardo
>>>>>>     _______________________________________________
>>>>>>     Pgrouting-users mailing list
>>>>>>     Pgrouting-users at lists.osgeo.org
>>>>>>     http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>>>>>          Georepublic
>>>> UG&  Georepublic Japan
>>>>          eMail: daniel.kastl at georepublic.de
>>>>>          Web: http://georepublic.de<http://georepublic.de/>
>>>>>          -----Inline
>>>> Attachment Follows-----
>>>> list
>>>> </mc/compose?to=Pgrouting-users at lists.osgeo.org>
>>>>      -----Inline Attachment
>>> Follows-----
Georepublic UG & Georepublic Japan
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110130/2546a4c3/attachment-0001.html
More information about the Pgrouting-users mailing list
