[pgrouting-users] iGO shp format
Miroslav Novta miroslav.novta at gmail.com
Mon Jan 31 13:36:52 EST 2011
Hello pgRouting group,
I am about using pgRouting with shp data in iGO internal shp format. There are some difference i have not see in other format. I am a beginner in pgRouting. I expect someone have solved the problem i am facing.
The iGO shp has three levels -1, 0 and 1in T_LEVEL and F_LEVEL specifying the different physical levels, of the way, only edges in same level are connected. There is also maneuvers table specifying maneuver restrictions.
Is pgRouting supporting these table specification? If it is supported specification, is there a cookbook how to prepare such data for pgRouting?
Thanks
Miroslav Novta
Type: application/pdf
Desc: not available
Url : http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110131/b2cb0526/iGO_internal_format_SHP-0001.pdf
More information about the Pgrouting-users mailing list
