[pgrouting-users] assign_vertices_3d source code & docs
Charles Galpin cgalpin at lhsw.com
Wed Mar 23 07:43:19 EDT 2011
Hi Miroslav
This is an implementation I have been using which I made after a discussion with Stephen on this subject. It is essentially an implementation of his ideas and works fine for me, but ymmv.
Otherwise search the email archives as I believe he posted his here at some point as well.
hth
charles
On Mar 23, 2011, at 6:44 AM, Miroslav Novta wrote:
> Hello list,
> I want to use the assign_vertices_3d() function developed by Stephen Woodbridge. I want to use it for iGO shp map format with "turn restrictions" too.
> Is there source code and documentation available on any public repository I may access?
-- Function: assign_vertex_id3d(character varying, double precision, character varying, character varying, character varying, character varying)
-- DROP FUNCTION assign_vertex_id3d(character varying, double precision, character varying, character varying, character varying, character varying);
CREATE OR REPLACE FUNCTION assign_vertex_id3d(geom_table character varying, tolerance double precision, geo_cname character varying, gid_cname character varying, source_zlevel_cname character varying, target_zlevel_cname character varying)
  RETURNS character varying AS
$BODY$
DECLARE
    _r record;
    source_id int;
    target_id int;
    srid integer;
BEGIN
    BEGIN
    DROP TABLE vertices_tmp;
    EXCEPTION
    WHEN UNDEFINED_TABLE THEN
    END;
    EXECUTE 'CREATE TABLE vertices_tmp (id serial)';
--    FOR _r IN EXECUTE 'SELECT srid FROM geometry_columns WHERE f_table_name='''|| quote_ident(geom_table)||''';' LOOP
--      srid := _r.srid;
--    END LOOP;
    srid := Find_SRID('public',quote_ident(geom_table),quote_ident(geo_cname));
    EXECUTE 'SELECT addGeometryColumn(''vertices_tmp'', ''the_geom'', '||srid||', ''POINT'', 3)';
    CREATE INDEX vertices_tmp_idx ON vertices_tmp USING GIST (the_geom);
    FOR _r IN EXECUTE 'SELECT ' || quote_ident(gid_cname) || ' AS id,'
            || ' ST_MakePoint(ST_X(StartPoint('|| quote_ident(geo_cname) ||')), ST_Y(StartPoint('|| quote_ident(geo_cname) ||')), '|| quote_ident(source_zlevel_cname) ||') AS source,'
            || ' ST_MakePoint(ST_X(EndPoint('|| quote_ident(geo_cname) ||')), ST_Y(EndPoint('|| quote_ident(geo_cname) ||')), '|| quote_ident(target_zlevel_cname) ||') AS target'
            || ' FROM ' || quote_ident(geom_table)
    LOOP
        source_id := point_to_id3d(setsrid(_r.source, srid), tolerance);
        target_id := point_to_id3d(setsrid(_r.target, srid), tolerance);
        EXECUTE 'update ' || quote_ident(geom_table) ||
                ' SET source = ' || source_id ||
                ', target = ' || target_id ||
                ' WHERE ' || quote_ident(gid_cname) || ' =  ' || _r.id;
    END LOOP;
    RETURN 'OK';
END;
$BODY$
  LANGUAGE 'plpgsql' VOLATILE STRICT
  COST 100;
ALTER FUNCTION assign_vertex_id3d(character varying, double precision, character varying, character varying, character varying, character varying) OWNER TO postgres;
-- Function: point_to_id3d(geometry, double precision)
-- DROP FUNCTION point_to_id3d(geometry, double precision);
CREATE OR REPLACE FUNCTION point_to_id3d(p geometry, tolerance double precision)
  RETURNS bigint AS
$BODY$
DECLARE
    _r record;
    _id bigint;
    _srid integer;
BEGIN
    _srid := Find_SRID('public','vertices_tmp','the_geom');
    SELECT
        ST_Length3D(ST_MakeLine(the_geom,p)) AS d, id
    INTO _r FROM vertices_tmp WHERE
        the_geom && Expand(p, tolerance) AND ST_Length3D(ST_MakeLine(the_geom,p)) < tolerance
    ORDER BY d LIMIT 1;
    IF FOUND THEN
        _id:= _r.id;
    ELSE
        INSERT INTO vertices_tmp(the_geom) VALUES (SetSRID(p,_srid)); _id:=lastval();
    END IF;
    RETURN _id;
END; $BODY$
  COST 100;
ALTER FUNCTION point_to_id3d(geometry, double precision) OWNER TO postgres;
More information about the Pgrouting-users mailing list
