[pgrouting-users] Get the edges in correct order
Stephen Woodbridge woodbri at swoodbridge.com
Mon Sep 12 20:40:58 EDT 2011
A bunch of us will be away at the FOSS4G conference in Denver this week,
so you might not get a quick answer to this. I think it might be
appropriate to write up a bug report in the ticket system and copy the
appropriate details of the problem from the emails.
If we have time to look into it we will post a response, but more likely
it will need to wait until next week when people are back and have time
to review the problem.
Thanks,
   -Steve
On 9/11/2011 11:20 PM, ancaag04 at alumnos.unex.es wrote:
> I found that the failure depends on the size of the imported topology.
> For example, if the database has 2000 or 1800 edges (or less), the order is correct.
> But if the database has 4000 or 6000 edges (or more), the order is wrong (is ordered
> automatically by gid).
> I do not know why this happens... I have not modified any function.
> -Antonio
>> Hi Antonio,
>> I'm not sure, but I did notice that your list of segments appears to be
>> ordered by gid. You might want to check if the function shootingstar_sp
>> has been modified and someone who added an "order by gid" clause to it.
>> -Steve
>> On 9/7/2011 11:35 PM, ancaag04 at alumnos.unex.es wrote:
>>> Hello Steve, I know the discussion, but the problem is different.
>>> For example, this image [1] shows a part of the city. I have marked the start and
>>> end edges.
>>> Now I have this query:
>>> SELECT gid, AsText(the_geom) AS the_geom
>>>           FROM shootingstar_sp('ways', 552, 1096, 0.1, 'length', true, true);
>>> This image [2] shows the results.
>>> [1] http://img828.imageshack.us/img828/7915/segments.png
>>> [2] http://img215.imageshack.us/img215/5103/resultsi.png
>>> I'm doing something wrong?
>>> Thank you.
>>> Antonio
>>>> On 8/31/2011 11:28 PM, ancaag04 at alumnos.unex.es wrote:
>>>>> Hello, i'm using A-star like this:
>>>>> FROM astar_sp_delta('ways', 2124, 2168, 0.1);
>>>>> The path is correct but sometimes I don't get the edges in the correct order.
>>>>> Is this normal?
>>>> I think the edges are always in the correct order, but some times the
>>>> edge is reversed from the direction that you traverse it on the route.
>>>> This has been discussed in the past and I have posted an algorithm to
>>>> correct that, but I do not have a link to it handy.
>>>> -Steve
>>>> _______________________________________________
>>>> Pgrouting-users mailing list
>>>> Pgrouting-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
